Results 1 to 16 of 16
    Jun 2019
    Kansas
    Default Which rear tire should I get?
    Gentlemen,
    Well Phooey....after reading the posts about how much everyone liked the Yokohama S Drive tire for the rear, I placed an order with Discount Tire Direct. They called today said that the S Drive tire was discontinued. So please advise me on my next option. We have a 2012 RT-Limited and a 2013 RT-S. They have only 4800 miles, but the 2013 is already at the first wear bars and I get goosey with old tires on my vehicles. Thanks for your help!
    Nov 2012
    North Las Vegas, NV
    There are several options in the 215/60R15 size. I have used this size, it works well and causes no problems. I am currently using a General Altimax RT43. 19,000 miles so far.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    , this was a Great tire …. and I recommended it very strongly, and many folks agreed with my choice …. But in reality time and Tire development advance …. currently the Vredestein Quatrac 5 is the best all- around tire on the market …. they ( the company ) still lists a 215/60-15 on their web site but it appears it isn't sold by anyone ….. But the 205/60-15 is available and will work on any Spyder ….. use the advanced search in the upper right corner and get the User reviews for this tire …. good luck …. Mike
    Sep 2015
    Chilliwack, BC. Canada
    According to their website, Quottro Tires out of the province of Quebec, Canada has this size. They’re saying they’re available at least.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Quote Originally Posted by bigbadbrucie View Post
    Thanks for the heads up ….. but for folks in the US they may not be able to get them … or the shipping would be prohibitive …… Mike
    Vermont
    I am on my 2nd General Altimax RT 43 rear tire, and it has 400 miles on it( due to me being back in the work force again).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Nov 2012
    North Las Vegas, NV
    Still doesn't make the General a bad tire. People need choices.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Vermont
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Kuhmo ecsta 225/50-15
    Sep 2013
    Houston
    Quote Originally Posted by DingerD View Post
    Gentlemen,
    The S-Drive is NOT discontinued. Lots of them in stock at the Yoko warehouse. I just got some in last week. They have discontinued some sizes but the 205/55-15 that we use is readily available.
    That said, the replacement is the Yokohama ADVAN FLEVA V70 in the same size and Tire Rack now has them in stock so they are transitioning that size now.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Gentlemen,
    I Dinger
    Toyo you can get the original dimension. 225 50 15
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Jun 2019
    Kansas
    Thank you all for your expertise. In reading about the Yokohama Advan Fleva V 70, I think that our colder conditions in Kansas may not be a good match for that tire. JCthorne, could you share your source for the S drive tire with me? If I can't find them, I'll go with Jeriatric's call and give the Kumho ecsta a try.
    Thank you all, and stay where it's cool. 102 degrees in Kansas today.
    Jun 2010
    Las Vegas
    I would recommend the General Altimax RT43 over the Kumho. I ran Kumho’s when we thought they were the only option available but they are not the best in wet conditions. I ride 30,000 miles a year so I have some real experience with them.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2012
    Pueblo Colorado
    We have been happy with the General Altimax RT 43 and the Kumhos Ecsta AST getting much better wear on the roads around here (Colorado, Utah, Okla, KS, MO). Discount Tire has been able to get them in and swap them out - all I need to do is bring them the wheel and we're good to go.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Sep 2013
    Houston
    The temperature 'warning' is the same as all other Yoko performance tires including the S-Drive. If you really are interested in hot dogging the bike when its 20deg outside then you need to be looking at Blizzeks, not Kumhos. We have ridden ours down to 16deg without difficulty. Yes, the tires have less grip when that cold. So do I.
    We get our tires for the shop through the commercial sales side of Tire Rack. The Yokos are normally shipped direct from Yoko's warehouse in California unless Tire Rack Shreveport has them on hand as that warehouse is closer.
    Very Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    I am very happy with this one on our 2014 RTL. The size seen here resulted in near perfect speedometer readings when compared to GPS.
    Those who say " I can't" will always be right.
    2014 RT Limited , pewter (magnesium?)
