Results 1 to 5 of 5
    Jan 2019
    Kansas
    Default Starter stuttering, computer rebooting when starting engine
    Hi all, I have a 2014 RT with about 29,000 miles and a weird problem. The starter hesitates, then kicks in while the computer reboots. See video at https://www.youtube.com/watch?v=FG3P...ature=youtu.be . It has happened on and off for a few weeks and seems to become more consistent. If I turn the engine off, then back on right away, the computer does not reboot again, but the starter still stutters a little.
    Battery is brand new and voltage reads fine. No error codes.
    Any ideas how to approach this? I am just afraid that one of these times the Spyder won't start at all.
    Thanks!
    Jul 2011
    Mitchell, Ontario, Canada
    It is obvious that the system voltage dropped below 10V during engine crank and the gauge cluster rebooted.
    1. Low charge on battery. Charge it up. Then figure out why the low charge.
    2. Dirty/loose battery connections. Too high a voltage drop. Could also be a cause for low battery charge.
    3. Bad battery. I don't care how new it is. Charge it and have it load tested.
    4. Bad bearing in the starter. Too high a current draw. Not likely so eliminate the other possible problems first.
    Jan 2019
    Kansas
    Interesting. I did not think it could be the battery since it is brand new, but I will take it to the shop and have them test it. Thanks.
    Jan 2019
    Kansas
    Spot on! It was a loose battery cable. All is good. Thanks!
    Oct 2014
    Fort Mill, SC
    We have a lot of smart people here.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
