Results 1 to 7 of 7
    Active Member mehcoib's Avatar
    Montreal, QC
    Default Is Throttle cable lubrication possible on '15 ST-S?
    hello,
    I tried to lubricate the throttle cable of my '15 ST-S Spyder... I even bought the recommanded tool to do it correctly, but... it seems it's sealed??
    Am I wrong? Here is the picture of what I got, I haven't been able to go further...
    Did I do something wrong or is it just not possible (useful?) to lubricate throttle cable of some Spyder models?
    Thanks for you help.
    Jerome
    2015 ST-S SE5 , Blue & orange
    Default Curious...🤔
    You probably have the fly by wire throttle and there is no cable to lube. Are you having a problem ..? If binding check grip and bar ends.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2015
    Oakley Utah
    Quote Originally Posted by mehcoib View Post
    hello,
    Did I do something wrong or is it just not possible (useful?) to lubricate throttle cable of some Spyder models? Thanks for you help.Jerome
    I could be wrong about this, but I don't think Spyders use throttle cables. It's all electronic controls
    2014 RTL Platinum
    Bossier LoUiSiAna
    not all
    think ‘13 & up are all fly by wire electronic control quick call to dealer or BRP should get good answer.
    Sep 2016
    Chillicothe, Oh.
    Photo looks like a fly by wire system to me. I don't see a cable.
    2015 RT , Black
    Oct 2015
    Lynden, WA
    I ride a 2013 ST-S. It is fly by wire.
    The throttle rotation and return are controlled by a spring in the end of the grip.
    Its a bugger to install and get set correctly.
    Good luck.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Montreal, QC
    thanks for your replies!
    No I have no problem with the throttle, I just tought it might be appropriate to lubricate that cable before it actually becomes a problem!
