Results 1 to 3 of 3
    Aug 2013
    SF Bay Area
    Default BRPConnect glitch fixed
    I have had some problems with starting the app on the dash. I see the phone go dark but the dash tells me to connect the phone. Thing is it is connected so why the problem? I checked the USB connection as well as the lightning phone connection as lint can get into the tiny hole where you plug the cable into. Nothing worked until I shut the phone off for a few minutes. Then, when I turned it back on and plugged it in the apps showed up in the dash. Not sure if its a memory thing or what but the iPhone 10Xs Max should not have storage problems. Weird.
    Basically shutting you phone down once in a while refreshes it and helps it to work better.
    2021 F3 Ltd , Magna Red
    Jul 2017
    Massachusetts
    My Samsung is the same way with the restarts, although my machine is a '17 RT and doesn't have BRP connect. Every morning at 3am it's been told to reboot itself and voila, everything is now right in the world.
    2017 Can-Am Spyder RT
    Aug 2013
    SF Bay Area
    Not sure if iPhones can be set to restart but I'll check. Thanks!
