Results 1 to 10 of 10
    Apr 2015
    Grand Forks, ND
    Default 2018 RT I want to sit higher(raise seat)?
    Any ideas on how to elevate the seat height about 1/2 inch on 2018 RT? Can I put spacers under the seat or any other ideas besides buying a new seat?
    Jim
    Jul 2010
    Las Vegas, NV
    Either a seat pad like an Airhawk, or , have an upholstery shop put in denser foam.
    Joe Meyer
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Give Dave a call. He's a site vendor.
    http://www.motorcycledave.com/
    Quote Originally Posted by Jeriatric View Post
    ….. you may be able (if you bevel the edges of the gel ) to just add it the seat foam WITHOUT making a cavity in your seat foam …. ask Dave …. Mike
    Apr 2015
    Grand Forks, ND
    Can I put a spacer under the seat on each side to raise it?
    Jim
    Apr 2012
    Not and have the seat lock. There are far more easy ways(not cheap)ways to elevate your seat. That does not mean it has to be super expensive either.
    Mar 2015
    Fritch, Tx
    Quote Originally Posted by JimboRTS View Post
    Jim
    Check with a local HVAC shop to see if they have a piece of 1/2" thick Arma-Flex insulation large enough to cut the right size and do a test sitting. If that feels good, strip the seat cover back glue the Arma-Flex to you original foam with contact cement then pull the cover back down and staple underneath like it is from the factory. If the 1/2" doesn't feel like enough use a second layer. If the HVAC shop does not have a scrap piece, full 3' x 4' sheets run about $50. I've used Arma-Flex to build about 7 or 8 motorcycle seats over the past 15 years. It is the most comfortable foam I have ever sat on in a motorcycle seat.
    If you deicide to give this a go, shoot me a PM for a few more details on what tools are best to use and a couple of tips on getting the seat cover glued back properly.
    Those who say " I can't" will always be right.
    Dec 2015
    Oakley Utah
    No, you can't mechanically raise the seat.
    Be careful about putting a pad or pillow on top of the existing seat, as it will not hold you as securely in place when you most need it.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    2014 RTL Platinum
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    Have you ever heard the story of The Princess and the Pea ?
    Really? ONE HALF INCH ?
    How about an extra pair of …. never mind.
    PLease excuse my abruptness, I am not usually stirred this way.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
