Results 1 to 4 of 4
    May 2012
    Southern California (Oceanside)
    Default High Beam Low Beam
    I don't understand how the high and low beam headlights work. Are there two bulb or one? Is it all mechanical positioning of one one bulb?
    I have a standard RT so no fog lights. What does or does not the little lens next to the headlight do...nothing..decorative?
    If I buy this is am I good?
    There is one light for both beams. There is a "shutter system" that comes into play when going from one mode to another. Low beam is partly blocked by the shutter. High beam is full on. You can hear the shutter opening and closing when you change from one to the other.
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Quote Originally Posted by Thopper View Post
    It is a shutter system, one bulb, one filiment. The Shutter drops down part way for low beam. You can hear it work with engine at an idle and dtand next to it.
    2014 RT SE6
    Jan 2015
    southern WI
    Don't forget that you can also aim your headlights for better results. LED's are a nice improvement too. The others have answered the shutter system part...
    2021 RT Limited
    2016 RTS , Pearl White
