View Poll Results: How much oil did you add prior to 6,000 miles (to those that passed 6,000)
Voters
15. You may not vote on this poll
  • None
    14 93.33%
  • 1/2 quart
    0 0%
  • 1 quart
    1 6.67%
  • More than 1 quart
    0 0%
Results 1 to 14 of 14
    Apr 2019
    Ft Pierce/Lk Placid
    Default How Much Oil Have You Had To Add Prior To 6,000 Miles?
    Just curious. I'm at about 800 miles, and it looks like it is about 3/4 of the way to needing to add a quart.
    Sep 2014
    Scotland
    If you're sure it was at full when new, that sounds like too high an oil consumption to me. At that rate, if it's being burned rather than leaking, I'd expect to see a haze of blue exhaust smoke.
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    Hope there's a good number of Rykers with ≥ 6K miles.
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Apr 2019
    Ft Pierce/Lk Placid
    Quote Originally Posted by Spyderlass View Post
    I had an RV that we got at about 6 years old and had about 25,000 miles. It burned a quart every 500 miles for the 12 years we had it. No blue smoke. Consequently, I added a quart of oil every 500 miles, and NEVER changed the oil. It got 10 quarts of FRESH oil every 5,000 miles, which is exactly how much oil it held, and was the exact oil change interval! I only changed the filter every 5,000 miles. But I digress.
    But yes, when I 1st checked my Ryker oil, it was up to the max. line.
    Jan 2009
    austria
    I reach the 6.000 miles next week - it seems that I needed NO oil in this time .. i filled in 0,15Liter but I didn`t know how to check the oil 10 seconds after the engine is switched off and not 2 minutes after that .. (like the Manual) - there are also no other issues on mine ..
    May 2016
    Noblesville, Indiana
    As mentioned in a previous post, just finished 4000 mile trek to the rocky mountains and back. No visible oil loss on the dipstick. Still at the full mark. Quite impressive!
    Apr 2019
    Ft Pierce/Lk Placid
    Quote Originally Posted by RykerUSA View Post
    Actually, you should use some oil. Otherwise your engine is NOT getting proper lubrication and will wear out quickly.
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Quote Originally Posted by Aufgeblassen47 View Post
    Um, so not true. Not sure where you heard that but it is simply not the truth. A proper oil control ring configuration will leave the correct amount of oil on the cylinder walls to properly lube the compression rings but NOT be so much they don't wipe the remaining amount from the walls and get burned off... And it is 2 completely different things as to proper piston ring/skirt/wrist pin lubrication vs oil control. Just sayin, and coming from 20+ years of auto tech experience. My 2010 Camaro that I have Supercharged @ 9psi uses NO oil. Yet manages to repeatedly put down 11 sec quarter miles times for the last 18k miles!
    Chuck
    Jun 2012
    Nevada
    What!!! That statement would be true if it was a TWO stroke engine.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Nov 2012
    North Las Vegas, NV
    My F3L doesn't need oil between changes. 9,666 miles on the last one and no oil added.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jan 2015
    southern WI
    Oil???? You mean these things need oil??? What kind? We haven't had to add any oil to the wife's 900. Smooth sailin' with 1600 miles so far
    2021 RT Limited
    2016 RTS , Pearl White
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    I added about 1/2 quart at around 3000 miles.
    I had an oil change at 4600 miles.
    I added about 1/4 quart just recently around 6k miles.
    EDIT: On my 2016 ST-S...998 V-twin.
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    2016 ST-S , Steel Black Metallic
    Apr 2019
    Clinton, MS
    True, based on old tech of many years ago. With today's materials of construction and advances in lubrication technology the usage between changes is often hard to detect on the dipstick.
    Apr 2019
    Ft Pierce/Lk Placid
    Update!!! I checked the oil today EXACTLY as the Manual specifies, and sure enough the oil is FULL! My bad for apparently checking it the wrong way before.
