Results 1 to 12 of 12
    May 2013
    Portugal
    Default Spyder RT limited 2014 Backrest. 857.607USD in Portugal
    Hi everyone I have a Spyder RT 2014 limited and am interested in buying a backrest. I'm looking for online because in Portugal it costs 857.607USD. I noticed that there are differences between the backrest for comfort seat and regular seat.
    How can I see which one I have?
    Previously: 2014 RT LIMITED SE6 (Silver Platinum Satin)
    Previously : 2011 RT TECHNO SE5 (Pure Magnesium Metallic)
    Quote Originally Posted by tomfil View Post
    First check the bottom of the seat Pan for the model number , second the OEM backrest is very expensive compared to the Utopia brand …. I've owned 8 + Utopia's …. imho they are the best made , and most comfortable ( it has the ability to give real Lumbar support ) ( PM me if interested ) ….. Mike
    May 2013
    Portugal
    Thank you for your help Mike. I'm really interested in the original backrest. The codes I have under the saddle are B0007 708001646 FAB / wo: 1543612 Is it possible to identify the model by these codes?
    Thanks
    Tomás
    Thanks
    Tomás
    I checked your numbers with CHEAPCYCLEPARTS.COM ( they have all OEM parts ) the only number that registered as a Part was - 708001646 - that comes back to a 2014 RT Limited seat assembly in Burgundy …. This doesn't answer your problem ….. You need to find out what was the STOCK seat that came with the 2014 RT Limited, this info should be available from BRP … either a dealer or from the company itself …. or from a member hear who actually bought a new one ….. sorry this is the best I can do . …. Mike
    May 2013
    Portugal
    The Spyder 2014 RT Limited Silver Platinum Satin came with Burgundy or Black seat.
    Well that ad only says it has an " Embroidered Limited Seat " ….. it doesn't say " comfort seat " ….. imho, the Comfort was an optional seat ….. as I said before - hopfully someone who Actually has one will chime in …. Mike
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I Tomfil
    I have a 2014 that buy in July 2018, I have a Utopia backrest, it has a lot of latitude for adjustments.
    It is very well made with quality materials Super, If you want to keep your original seat
    https://www.utpr.com/spyderrt.html
    FlyBoy2121
    2014 RT ltd , original original Cognac
    May 2013
    Portugal
    I saw on Utopia website how to distinguish the stock seat from the confort seat.
    https://www.utpr.com/spyderrtcomfort.html
    I bought a used Spyder and that's why I was in doubt about the seat model. Is it worth investing in the confort seat? I have to decide now before buying the backrest.
    Thanks for the help
    Thanks for the help
    Well which one, that's a tuff question …. the comfort seat imho ,is made for a person 6 Ft. plus or very long legs ….. only you can decide what might fit you better ….. I don't think the comfort seat has any different foam, so both should feel about the same …. I'm 5' 11" with 32" inseam and the stock RT seat is fine for me.... I will say the Utopia is excellent choice …. every touring bike I have owned got one ….. I found a nice feature that Utopia doesn't actually put on their backrests …. It's a " lumbar " support, but you can easily add one …. what I did was TILT the very bottom of the backrest forward so it's now at an angle " / " …. to keep it there I taped a 1/2" piece of wood to the upright bar ….. the seat still functions the same as it did without the shim …. good luck …. Mike
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    I do not like the brp pad .The pad does not adjust independent of the back rest ,so it does not conform to your back .
    2018 RTL , dark blue
    Bryant, Arkansas
    All came with a stock seat, the comfort seat would have to be ordered special
    Cruzr Joe
    Jul 2016
    australia
    i have just sold a brp backrest and the bracket assy for 200.00 aus.i still have a new original delivery red seat for a 2016 rt special.
