Results 1 to 8 of 8
    Default Consumer Reports - Vredestein Quatrac 5 tire
    I just discovered C. R. did extensive testing of the Quatrac 5 , since I am not a member I can't see the entire test report .... but what I did see ...They liked it a lot ...……...Mike
    May 2017
    Mesa, Arid-Zone-A
    Going to be my next tires. Thanks..... Jim
    Semper Fi
    Mar 2015
    forrest above Reno, Nv
    Order a set for the front when this trip is done.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    Ordering a set next week, when what do I see behind the batter at a Cleveland Indians game?
    A large banner advertising KENDA tires!
    What to do, what to do? .....NOT!
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    Here are the ratings charts from the report. Note several tires have higher overall ratings.
    Performance all season CR rating 1.jpg Performance all season CR rating 2.JPG
    Ultra high performance CR rating 1.jpg Ultra high performance CR rating 2.jpg
    Here's their summary comment on the Vorti.
    Highs
    Impressive handling, dry braking and hydroplaning resistance. A quiet tire.
    Lows
    Stiff ride on impact.
    CR's Take
    A very good choice with high levels of grip and handling. Based on CR's test, the Ultrac Vorti has relatively good tread life compared to peer models.
    And for the Quatrac.
    Highs
    Very good hydroplaning resistance and snow traction. Very quiet.
    Lows
    None.
    CR's Take
    Well balanced for most all driving conditions.
    This is all well and good ….. But the Vorti doesn't come in any sizes to fit any Spyders …. I can show you many, many tires that are better than the Quatrac 5 , but if they don't fit the Spyder what's the point in recommending them ????? , or are you making a point I'm not understanding !!!.... Mike
    No particular point being made. I didn't scan the tire size lists. Since you said you don't subscribe to CR I thought I'd just present the information directly from their site as is. I did find it a bit interesting that a couple of tires you've recommended in the past, the General and Michelin, rate better than the Vredestein, but again, I didn't check the size availability.
