Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Member kissfan's Avatar
    May 2019
    Brooker, FL
    Quote Originally Posted by rdkarl View Post
    When you are using BRP connect Music set up like this, does the joystick allow you to increase/decrease volume?
    Yes, but you have to get out of BRP Connect and back to the standard dash (like you were using Bluetooth connect to the phone.)
    My only vice is passion for KISS.
    Oh, and food.
  2. #27
    Florida
    Quote Originally Posted by kissfan View Post
    OK, that was what I was experiencing also when I setup a small music library as you suggested. Up and down on the joystick was changing to the next song. Thanks.
  3. #28
    Jul 2011
    Mitchell, Ontario, Canada
    When you are on the main screen and playing tunes from your phone. No matter if you are using the BRP music app or not not. The artist and song title should appear on the right side of the screen. Up and down on the joystick will control the volume. Long press down will pause the song. Press right will change to the next song. Press left will restart the current song. Long press left will go back to the previous song.
  4. #29
    Florida
    I figured out how to make BRP connect Music work correctly...I bought an iphone. Works as it should.
  5. #30
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by JP58 View Post
    I don't use BRP connect. I just load music on my phone from Windows Media player. Pair phone and helmet to bike. Go to Bluetooth on your settings and it will load and play. I use Samsung music app on my phone.
    That is exactly what I do with my Android. Just pair with bike and use Goople Play Music. Set up Bluetooth and enjoy. Forget BRP Connect. Waste of time..
    2018 RT Limited "Blondie"
