I use a Kobalt Metric 1/2-in Drive 12-point 36mm Shallow Socket P.N. 338135 for $8.98 (Lowes). It's short enough to get between the muffler and the axle nut on my RTL while mounted on a torque wrench. It's 12 point but does the job. I'm too lazy to weld.
h0gr1der
Being in a small town, I don't have easy access to stuff like that on the shelf and don't like to buy tools online. I did check a couple of local pawn shops for 36mm open end/box end wrenches--no luck there of course. So, I figured since I have a welder, chop saw and grinder why not just make what I need from the sockets that were way to long to start with.
Those who say " I can't" will always be right.
I commend you on skills I don't possess. On this forum, seems like a lot of folks are very capable at making/designing anything. Wonder if this reflects on the Spyders shortcomings?
As an aside, I also bought this for cheap, 36mm box wrench off of ebay-https://www.ebay.com/itm/Sunex-936-36-MM-Jumbo-Combination-Wrench-CR-MO-36mm/323305411708?epid=1111819199&hash=item4b4681147c%3 Ag%3AwxcAAOSwRjlc8-tV&LH_ItemCondition=3
For some reason I notice that the 36mm stuff is slightly loose on the Spyder axles. Still works, but hard to keep a bite on the bolt without an assistant. Doesn't matter the brand of tool, all of them are loose. Suspect the axles are slightly smaller than 36mm.
h0gr1der
Well done....
Great Idea for those with skills and equipment. Those without can take the parts and plans to a welding shop and have it done. The rest can shop Harbor Freight and the like for other solutions. I use a large cresent wrench on the holding side and the socket and torque wrench on the other....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
I use a 1" 7/16 boxed/ opened end wrench, 12pt. Bruce
New to Sue and I
Gone but not forgotten
RTS 2011 SM5, 95,000 miles
appreciate that. I never bothered to calculate the conversion to SAE. Even if I had, I suspect that size might be a little difficult to find. That said, you know I will sort through the old wrenches in local pawn shops--it's an addiction, I know.
