Results 1 to 10 of 10
    Jun 2012
    Nevada
    Default Anybody installed Ryker Passenger seat and foot pegs?
    Has anybody installed passenger seat and foot pegs yet.
    The passenger foot pegs when closed stay loose and rattle around.
    I installed these myself and the dealer has not installed any yet so don't know anything.
    Not sure if I got a bad set, hope this is not normal.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Nov 2018
    N.E. Ohio
    I installed myself and no rattles no problems. cueman
    Aug 2015
    Crosby,Texas
    Dec 2018
    NY
    Dealer installed. No rattles or other issues.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Quote Originally Posted by leenanj View Post
    May be a bearing or spring missing. They provide the friction to keep them up, and reasonably tight.
    Edit: Stung again. I've been away(from SpyderLovers) since before the Ryker was being sold. I must start paying closer attention.
    Jun 2012
    Nevada
    I ended up removing the foot pegs, taking them apart and adding a washer to each arm.
    They seem much stiffer now, even added a rubber bumper where it hits.
    Can Am's quality control could use improving a little.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Kansas
    I actually had no issues installing them and they don't rattle at all on my Rally
    Jun 2019
    Florida
    I installed mine and they do seem a bit loose. I have not had the opportunity to ride it yet, so I do not know if it will be loose enough to rattle. I agree with you that they need better quality control. The seat went on easy.
    Dec 2023
    Australia
    Any fixes? I just installed mine and each one is loose in different position's, left one is loose when down and the right one is loose when up?
    Really weird/not happy with the quality compared to price for oem
    Any help is much appreciated my only option in my mind is to get the showchrome ones to make up for the crappy oem ones
    Quote Originally Posted by Flickdubs View Post
    Yep, the OP posted back in post #6:
