2016 RT floorboards on 2012 RT
Hi all, not sure if this has been discussed anywhere, but I want to change the footpegs on my 2012 RTS with floorboards from a 2016 RTS. Want to know if anyone can tell me if they will fit first off and second, if its a fairly straight forward swap or if I need to change the side mounting brackets too.
the parts between a 2016 and 2012 are not interchangeable. the two are totally different, different motor and frame everything. You can get after market floorboards that will fit the 2012 RT.
Thanks CopperSPyder. Good to Know. I'll keep looking at the options.
