Results 1 to 3 of 3
    Apr 2019
    Oakville, On, Canada
    Default 2016 RT floorboards on 2012 RT
    Hi all, not sure if this has been discussed anywhere, but I want to change the footpegs on my 2012 RTS with floorboards from a 2016 RTS. Want to know if anyone can tell me if they will fit first off and second, if its a fairly straight forward swap or if I need to change the side mounting brackets too.
    Nov 2018
    Waynesboro, PA
    the parts between a 2016 and 2012 are not interchangeable. the two are totally different, different motor and frame everything. You can get after market floorboards that will fit the 2012 RT.
    2012 RTL , Brown
    Apr 2019
    Thanks CopperSPyder. Good to Know. I'll keep looking at the options.
