Results 1 to 23 of 23
    Jun 2012
    Nevada
    Default Headlight modulator install
    Installed these LED headlamps on my Ryker 900.
    https://www.amazon.com/gp/product/B0...TF8&pscInstall
    Then installed this universal headlight modulator by Kisan that will drive both LED lamps.
    https://kisantech.com/p75w.html
    It is working great, I'm a firm believer in modulators and being seen, installed them on all my bikes.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    May 2019
    Illinois
    Did you have any issues with installing the LED? I tired to a different part number from same manufacture and the housing on bottom was a little too thick and didn’t allow the retaining clip to latch on.
    May 2012
    Southern California (Oceanside)
    The modulator says not compatible with the can bus system.....
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Copied directly from their website: ■ DO NOT use on bikes with bulb-check system or CAN-bus monitoring.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Jun 2012
    Nevada
    Quote Originally Posted by BoilerAnimal View Post
    I am using the above LED's and Kisan modulator without any problems or errors on the Ryker.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Jun 2012
    Nevada
    Quote Originally Posted by Colonjrc View Post
    The white plastic ring that locks the bulb in the housing was a tight fit, I ended up using a dremel and removing the two raised sections on the ring.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    May 2016
    Quote Originally Posted by leenanj View Post
    That's usually the way it works. No problem at all until it happens. Just hope you're some place that's not to inconvenient to get to the shop. And that the problem(s) are easy to fix. Good luck!
    2013 RT-S SE 5
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    2019 900 Rally , Black
    Active Member poli's Avatar
    Feb 2019
    East Texas
    I remember seeing a video from TheSmoaksVlog where he warned about people putting the decorative led lights on Spyders and it messing with the can-bus system after a while. Not sure how the system works but it apparently doesn't like some add-ons. Take the warning as you want.
    Spyder F3-S Special Series my traveling ride
    Ryker Rally modified for dual sport duty
    Honda Grom heavily modified for dual sport duty
    Ducati Scrambler Icon Dark my other traveling ride
    Jun 2012
    Nevada
    No fears, even with the headlights disconnected the Ryker reports no errors
    so obviously there not monitoring for malfunctioning headlights.
    Used the same set up on my Goldwing and Harley that are Can Bus with no problems.
    Grow Some!
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Clinton, MS
    Reading on their site it looks like they make one that is compatible with can-bus, just not the one linked.
    May 2016
    Grow Some!
    The problem usually arises from an interference that eventually occurs from incompatible components. You may get lucky and never have a problem. I hope that's the case. If not, where will you be when it occurs? Down the street or a couple of hundred miles from home or a dealer? Will it just be a limp home error or something that stops you dead? How much will it cost to remedy?
    Generally, I try to not make it a habit of asking for trouble. But, it's your ryde, your life and won't bother me in any way. I wish you the best of luck; you may need it.
    PS: I've got a healthy set!
    2013 RT-S SE 5
    Kansas
    I absolutely hate headlight modulators and think they should be illegal on anything but an Emergency Vehicle. On another note I did install a brake light modulator where it flashes the brake lights 4 times fast, 3 times slow and then solid. So far no issues. Also if you get the correct H4 LED headlight bulbs there is no trimming necessary.
    Jun 2012
    Nevada
    Easy access to splice in the modulator.
    Blue wire at this plug goes to both Hi Beam headlights.
    Headlights are on a dedicated line with own fuse so no problems with Can Bus.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Jun 2012
    Nevada
    Its a beautiful thing, if they don't see me coming now they never will. LOL
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    Bossier LoUiSiAna
    It was night time so had to shoot a flashlight at sensor.
    https://my.pcloud.com/publink/show?c...nj5nEfwBIiNKPV
    aren’t dual bulbs supposed to alternate the modulation?
    May 2016
    The ones I've seen alternate between high and low beam, not just on and off.
    2013 RT-S SE 5
    Jun 2012
    Nevada
    That would actually be illegal to flash or alternate hi/lo.
    You can only modulate hi or low beam, preferably hi beam, that way you can flick the switch to turn it off during the day if you want.
    A photo sensor automatically turns it off at night and prevents it from modulating.
    -Jimmy
    2019 Ryker 900
    2018 Honda Goldwing
    May 2016
    https://www.webbikeworld.com/motorcy...ht-modulators/
    Probably why I thought it was alternating between high and low beam.
    2013 RT-S SE 5
    Active Member Sarge's Avatar
    Yanceyville,NC
    I plan to convert my 2015 RTL to LEDs and install a modulator very soon. That is, as soon as I can find the best, brightest, most reliable, least troublesome and easy to install bulbs. I want to do the headlights and fog/driving lights. I had a modulator on my 2010 Kawasaki Voyager and people definitely saw me. I think it's the best safety device you can put on a bike or trike.
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Jun 2020
    New Jersey, USA
    Where ls a good place to run the red sync wire between the two lights on a Ryker when installing the Kisan dual plug-and-play modulator?
    Active Member MrMagicFingers's Avatar
    Apr 2020
    Dartmouth, Nova Scotia, Canada
    I love mine as well. I currently have a modulator on my Goldwing but will be adding one to the Spyder over the winter when I go through my electrical list of "Things to do".
    It has literately Save My Life.
    https://youtu.be/bN_1Gu1_2Rc
    Tim
    Current - 2010 Spyder RTS
    1) Experience is something you don't get until after you need it.
    2) A closed mouth gathers no foot.
    3) IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU HAVE TIME TO DO IT OVER??
    ___
    Horsepower is an illusory mathematical equation; Torque is REAL, and is the source of all good things in the world.
    The problem is not the problem. The problem is your attitude about the problem. Do you understand?
    Please check out my pics!!
    Aug 2020
    California
    Today I install some h4 led to my ryker rally. It has a build in fan. Its so loud, it sounds the fuel pump noise. The lights looks nice but is very loud.
