Results 1 to 7 of 7
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    Default gauge replacement
    I am replacing the temp gauge and the fuel gauge with a clock and volt meter gauges. I have the replacement gauges from prosport INC. the clock gauge has 4 wires and the volt meter has three wires. Both of the gauges stock harness has three wires. Any body have an idea which stock wires are to be used? I've got them mounted but no combination seems to work.
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    What year RT? BRP changed the wiring in `14 I think... also a link to the gauges would help.
    JT
    Jun 2015
    Hampton Roads, VA
    The clock may require battery power? There is no battery power on either of gauges that came out (always hot). You will prob have to run wires to the battery if you haven't already. Since there is a clock on the LCD already, I'd suggest a cigarette lighter or dual USB in one side. Then after you run the battery wires (included) you can tap them to run over to the voltage monitor. I left off the third wire on voltage monitor (battery - yellow), so it wouldn't drain anything. All it does is allow a cool little display on power up. I'm assuming the voltage monitor is the $18 - $20 version that most get. It is always good to have one set of wires connected to the battery for future expansion.
    Active Member Raknid's Avatar
    Central NJ
    I have the clock and volt meter. Given the USB proliferation since I changed them in 2012, I would likely go with the double USB vs clock today.
    2012 RT-SE5
    Feb 2019
    Indiana
    2016 RT limited MAPERFORMANCE digital gauges
    Active Member Sarge's Avatar
    Yanceyville,NC
    I have a 2015 RTL and was considering replacing the two gauges also. Question: So ... is the +positive lead to those gauges only "hot" when the trike is ON?
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Jul 2018
    Saskatchewan
    Quote Originally Posted by nightcruiser View Post
    Got photos?
Tags for this Thread
