USB and 12 v gauges
When I traded in my 2014 RT LTD the dealer wanted the original gauges back on the bike so I have the 12 v and USB for sell.
$25 for both plus shipping
Customer Support
What did you use the 12v for? i'm interested.
2015 Pearl White RTL
Baja Ron Sway Bar
Russell Day Long Seat
Strobe Brake Light
Mirror Mount Turn Signal Indicator
Sometime I used it to charge my phone if I forgot the fast charge usb cable. I had one on each side.
I can't find which wires to use for power for the new gauges,, can you give me any ideas?
I honestly dont have a clue, but if I had to guess it is the same wires behind the fuel and temperature gauge that is there now.
The wires for the USB are in the dash, the wires for the 12volt will have to be run directly to the battery if you don’t want any electrical problems.
Cruz’s Joe
Where do you find the USB in that size to fit hole ..
I can't remember where the dealer got them from, I had them put on when they built the bike new.
do yourself a favor and run a fused wire up from the battery. In the long run you will be glad you took the time to take the parts off the front to run the dedicated line vs. tapping into the factory harness and possibly overloading a circuit or shorting something out.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
