Fuel gauge stuck on full - any fixes?
Hi Guys
2014 RTs - My fuel gauge is stuck on full. Has been for the last week or so.
How do I get it to react as it should?
I had the battery disconnected yesterday and it was still the same.
Cheers
Frank
Analog or digital gauge? If it’s the analog disconnect it at the dash & use the digital. If it’s stuck too can try carefully using a coat hanger to poke down filler neck & maneuver the float carefully & or let the dealers tell ya
(Maybe use a plumbing camera to see https://www.walmart.com/ip/As-Seen-O...-Cam/800735601 )
Reason: Link
Gauge is analog. And yes I do have a inspection camera.
Would like to keep it standard as possible
You can disconnect the analog gauges and the digital ones will come up on the cluster. If the digital fuel one works properly it's a bad analog gauge. If not it's the sending unit.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
On my wife's 2012 RT, the analog fuel gauge was wildly inaccurate and the digital gauge was much more accurate. I eliminated the analog and added a clock and volt meter to the dash cluster.
I am not sure if the 2014 was improved? If not, a consideration (regardless of analog state) may be to use the digital gauge.
Did the same, love the look and the gas/temp guages on the digital guage are more accurate...
All of the advice above is good. I just want to make it very clear that both, the fuel and temperature gauges must be disconnected for the gauges to show up on the screen.
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
Did you add the Magic Mirrors recently? The magnets caused the analog meters to be affected.
Hi Guys
Cheers
Frank
That would seem to imply that it's not getting any power to it I think.
2014 RTL Platinum
I've had no trouble with the fuel gauge on either of my 2014 RTs, other than accuracy.
2014 RTL Platinum
I had the same problem with my 2015 RTSSE6. After the dealer changed the analog fuel gauge and the fuel pump sending unit it still didn't fix it. The dealer changed the entire digital dash to fix the problem.
