Results 1 to 6 of 6
    Sep 2018
    Chicago
    Default Am I leaking oil? Picture included
    So I just took out the Ryker from the garage and saw a little oil spot on the ground and oil sitting in a crevice. I attached a picture of where the oil is settling.
    What do you guy's think is going on?
    Jan 2019
    Charles Town, WV
    When I first got mine and rode it a little I found some oil in the same spot but none on the floor. I wiped it off and have not seen any since. I am thinking it was just a protective coating of oil on the engine that ran off after the engine was hot.
    Jun 2019
    Florida
    I too had a very small film of oil substance in that exact area. I wiped it dry and have had no more collect there. I am thinking it might have been cosmolene.
    May 2019
    Washington
    same here
    Dec 2018
    Missouri
    Yep, had the same. Nothing since cleaning it off and that has been awhile ago. Clean it and report back after a few more rides. Oh... Please. And Thank you.
    Florida Swamp
    Slide a clean piece of cardboard under it when you park it. If even one drop comes out, you will be able to see it on the cardboard the next day.
    2019 F3-S , Black & Silver
