Results 1 to 12 of 12
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default How I envision a Can Am designer
    If I was on that team, I would have picked this up during the first prototype usability tests.
    Fill ups are such a pain. The nozzle shuts off long before the tank is full. So I have to hover the lever to keep the gas going. Also, the tank gas input (or what ever it's called, I'm IT so its an input) is so small I cant peek in and see if its full.
    I also would have noticed the gas gauge doesn't work I build software systems for a living, and in software, testing is a high priority. And tests are done by people with different perspectives. Engineers, analysts, and everyday users test and provide feedback.
    I get the impression Can Am designers ARE NOT riders. More like some urban Yuppie hipster college boy on his electric scooter.
    2019 Rally , Black
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Sometimes I think you may be on to something!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Jun 2019
    Canuckistan
    Quote Originally Posted by BoilerAnimal View Post
    ...And Most times, I do not.....
    Cheers
    E
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Some different types of fuel have specially sized nozzles to prevent accidentally filling a tank with an incompatible fuel. That's the reason for the small hole.
    Early pump shut off? Don't put the nozzle all the way into the tank, or if you do, once it auto stops the first time, cheat a little by inserting it an inch or two into the tank and slowly bring it up to your desired level(usually when fuel is seen gurgling from the little slits by the filler hole).
    The analog gas gauge is a joke. The digital gas gauge is actually quite accurate. Their relative importance of use to each individual, seems to depend on whether they primarily ride where stations are plentiful, or where you may or may not see a station for a couple hundred miles.
    May 2016
    Yep
    Quote Originally Posted by Entropy View Post
    Cheers
    E
    That’s why I qualified my statement with “sometimes”.
    2013 RT-S SE 5
    Kansas
    Interesting, I have filled my Ryker up 3 times and have not had a single issue. And if there's an analog gauge on the Ryker I haven't found it, the whole gauge cluster is digital.
    Apr 2012
    Quote Originally Posted by KC61 View Post
    I know "0" about the Ryker, and little, very little, about the 1330 models. If you're happy, we're happy.
    Kansas
    I thought this was the Ryker forum?
    Apr 2012
    May well be. I didn't look.
    Edit: His fueling complaint, and my response, is applicable to all Spyder's.
    Northern Kalifornia
    No one really knows how much fuel can be stuffed into a spyder's gas tank.
    Nov 2018
    N.E. Ohio
    On my Rally I can put more fuel in than what the capacity is. Either way, something is wrong. cueman
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Rogue Hawk View Post
    If I was on that team, I would have picked this up during the first prototype usability tests. Fill ups are such a pain. The nozzle shuts off long before the tank is full. So I have to hover the lever to keep the gas going. Also, the tank gas input (or what ever it's called, I'm IT so its an input) is so small I cant peek in and see if its full. I also would have noticed the gas gauge doesn't work
    The gas tank filler tube is pretty much standard on all motorcycles made for the American market. And, gas fill level gauges are going to have some degree of inaccuracy because of the irregular design of the tank on any motorcycle. At least they have a gauge instead of the reserve petcock method of knowing when you're running low.
    You're not a fan of BRP. We get it. Can't understand why you are even on a forum for enthusiasts.
    2014 RTL Platinum
