Results 1 to 11 of 11
Thread: Picture game
    Bossier LoUiSiAna
    Default Picture game
    Sorry no prizes to offer , but can you spot what’s wrong?
    (Sideways pics not accepted)
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    The Nannies gyroscopic stabilizer is off and the Spyder is tipped over?
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
    Idaho
    You're traveling 20 to 30 mph and the safety notice is still showing!
    2014 Copper RTS
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    it was a slow day at the "institute" so you posted this.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Bossier LoUiSiAna
    , now what to do?
    FYI the scenario: would randomly stall code while slowing down or at stops. Looked for codes found P1175 combined with some service work 1/18 had air filter & spark plugs changed, still had issues just not as often 4/1 had fuel filter changed, great improvement, but not 100%. So according to SpyderCodes P1175 : ECM. system too rich bank 2. Sometimes when it stalls I can start right back up but it's still in gear it N as the SE5 is suppose to go to & then sometimes the mode screen comes back while I'm at speed as seen in the pics. So last couple of days the stalling has increased & I managed to get theses pics, still in talks with my tech & of course it fails to show itself for him so I'm trying all my options.
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Jan 2019
    Blue Mounds Wi
    MAP hoses?
    if not done already replace them with silicone hoses and also check intake manifolds for similar cracking ...
    ​2012 RS sm5
    Feb 2012
    Spring City,Utah
    looking for something else and found this. B what was the final resolution?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2018
    millsboro,delaware
    That mode screen may be a clue that the computer is losing its connection with battery for just a split second which could cause possible code setting while moving.I would look first for loose connections or ground strap problem(engine and battery must be grounded to frame).I know chevys had a problem where the ignition switch would wear and you would hit a bump and motor would stall.Try wiggling key while driving.Another idea would be to hook a test light up to the ECM fuse,then drive and take notice if the light shuts off,or blinks when the bike stalls.That would just confirm that the stall was caused by a lack of power to the computer.
    : 2017 RTL ORBITAL BLUE
    Bossier LoUiSiAna
    should know this week, combined problems with starter then holidays to slow things down a bit.
    Starter issue:
    https://www.spyderlovers.com/forums/...tally-confused
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Bryant, Arkansas
    Quote Originally Posted by h0gr1der View Post
    😂😂👍. Good catch
