Results 1 to 18 of 18
    Invalid Emails
    Jul 2019
    Illinois
    Default Parking brake failure message
    I have changed out the brake switch and spring and still have the failure message. Brake fluid topped off. What else is causing massage. Is there a reset sequence for the error code maybe?.
    2009 GD , Red/Black
    Apr 2017
    North Central Florida
    Quote Originally Posted by Rogue1 View Post
    More info. is necessary.
    Does the brake failure message really specify the PARKING brake ?
    Is your parking brake actually stuck ON or OFF ?
    The most common parking brake failure is the parking brake motor/solenoid.
    Knowing the model and year might help.
    You can put that info. in your signature,
    here VVVVVVV
    Invalid Emails
    Jul 2019
    Illinois
    [It just says Brake Failureq. 2009 Gs
    QUOTE=Easy Rider;1456513]More info. is necessary.
    here VVVVVVV[/QUOTE]
    2009 GD , Red/Black
    Apr 2017
    Well that does NOT necessarily mean "parking" brake.
    Is there an obvious problem with the parking brake ??
    I think you need BUDS connected to read all the codes present.
    Invalid Emails
    Jul 2019
    Illinois
    Parking brake works fine. Only electrical connection that would trigger a code for brakes is the parking brake switch. Dealer told me there are no sensors at the brakes themselves. So we both figured it was switch.
    2009 GD , Red/Black
    IMHO ….. If you have any brake message it is usually due to LOW Fluid ….. correcting that may solve your issue ….. for a complete RE-BOOT disconnect the battery for 10min. ….. good luck ….. Mike
    Invalid Emails
    Jul 2019
    Illinois
    Thanks. Fluid has been topped. Off. Will try the battery
    2009 GD , Red/Black
    Jul 2011
    Mitchell, Ontario, Canada
    The dealer told you there are no sensors in the brakes! That there is just too funny!
    Stop guessing and get the active fault code. You posted in the GS/RS forum so I will guess that is what you have. You do not tell us the year and that could make a difference. So the most likely way to get the fault code would be. With the fault active on the screen.
    With engine running. Press the mode button repeatedly until "engine hours" (total hours) shows on display. Make sure you do not release the mode button when you get to "engine hours"
    While still holding the mode button. Flash high beams 5 times within 2 seconds.
    If there are no active faults "No Active Fault Code" will be displayed.
    If there is an active fault, an alphanumeric code will be displayed.
    If there are more than one active code, you may press MODE to cycle through them.
    By your description it sounds like a low pressure fault. Usual cause is old brake fluid. If it is there is a way to clear the fault.
    Disconnecting the battery is a waste of time and effort.
    Invalid Emails
    Jul 2019
    Illinois
    This is my first time on the forums and have received good info. I will try the codes now. I have an 09gs.
    2009 GD , Red/Black
    Mar 2019
    France
    I had the same thing the day I bought mine - to cancel the message is a strange thing
    Turn on ignition and then stand and I mean stand on the brake pedal until you hear a second click - first one is the brake light - it worked for me
    2009 GS SE5 , Red (Ferrari Red :) )
    Invalid Emails
    Jul 2019
    Illinois
    C0049. Shows brake fluid level or sensors. Level is full. Dont know how to check resistance on the sensors to see if they work.
    2009 GD , Red/Black
    Invalid Emails
    Jul 2019
    Illinois
    Not sure what else to look for here. The 2 plastic probe type sensors are in place under the reservoir but sit loose. May be normal. Dont see how those work.
    2009 GD , Red/Black
    Jul 2011
    Well now you know it is a brake fluid level sensor issue and you can concentrate on that. Make sure the magnet is still attached to the float. Make sure the sensor is fully seated on the back of the reservoir.
    Invalid Emails
    Jul 2019
    Illinois
    I think you guys nailed this mystery for me. The code is not showing now. I topped off the resevoir all the way up till it overflowed. code still showed. Back half of resevoir never moved in height. I topped it off as well. No code. Am i to assume the resevoir is a 2 compartments. ?
    2009 GD , Red/Black
    Jul 2011
    Yes it is. The rear if for the front brakes and the front is for the rear brakes. That's why there 2 caps to fill as well. So now you have to clean up all the extra brake fluid. It will strip paint. Brake fluid is water soluble. So easy enough to clean up.
    Invalid Emails
    Jul 2019
    Illinois
    Done. Thanks for all the help. Really not sure why the dealer didnt even suggest this or k ow how to get the code to figure it out. Been dealing with this since october
    2009 GD , Red/Black
    Apr 2017
    WHAT YEAR AND MODEL DO YOU HAVE ?
    Unless maybe you have the first Spyder ever built, I'm pretty sure that is absolutely, positively FALSE.
    I think you need a different dealer.
    For instance, I had a brake failure indicator come on because I was "riding the brake" a little.
    Apr 2017
    Yes. BUT having it WAY overfilled can cause problems too.
    And given what you have now discovered, I KNOW that you need a different Spyder shop.
