Results 1 to 8 of 8
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default For Those with M2 Shocks
    Looking at upgrading shock on the RT, been looking at Elka and M2. Not sure why to choose one over the other they both seem like good shocks and both appear to have great customer service. I don't see my self adjusting the shocks all that often, I just would like a more stable, and better handling ride. Have already do the sway bar, laser alignment and car tires and is pretty damn good hoping the shocks will put it over the edge.
    To be continued....
    Sep 2014
    USA
    whatever you choose the M2 for me has set the Spyder over the top. That was with the fronts only. Just installed the rear shock finally and finishing up that project and more.
    Cant wait to see the difference for the rear end now..
    Once you set the shocks you may never touch them again
    Northern Kalifornia
    Been running the rubber donuts in my OEM shocks now for 4 years. They cost about $7 and work great and don't ware out. Along with Ron's sway bar it's like riding a rail through the curves.
    Feb 2019
    Portland, Oregon
    Rubber donuts? Please describe.
    May 2012
    Southern California (Oceanside)
    I am curios about the donuts as well.....bushings? Why do people want new shocks anyway. I guess I would need to ride a spyder with the aftermarket shocks to understand. I understand stiffening up the suspension on a car for less body lean more grip etc. but I don't wish for a harsher ride on the can am.
    Jul 2016
    Woodbine, Maryland
    From what I understand and I will testing on a friends this weekend, it is more controlled/smoother ride rather than a harsher ride.
    To be continued....
    Northern Kalifornia
    https://www.holley.com/products/susp...nts/parts/1287
    This is not the correct spacer for a small coil shock like the spyder has. It is just an example of what they look like. Search Mr. Gasket for the correct size for your shock. The one I got was a little over sized so I cut about an inch off of it so as not to make it over lap its self. Lift your spyder up just enough to relax the spring and use dawn liquid soap to help squeeze the spacer in place. I placed mine in about the center coil. The size I got was for a quad that had a snowplow mounted on the front. The spacer lifted the front of the quad just enough to keep the blade from dragging. About and 1".
    Sep 2014
    USA
    I just test drove around with the new rear M2 shock.
    Now I have them all around the bike.
    What a amazing ride now.
    I also notice the compressor doesn't kick on as the rear shock has been doing its job now..
    No tweeking with the rear shock adjustments seems to be right on!!
