Blank plates beside key
I have a 2019 F3 base model. On each side of the key there are blank plates that are factory prewired. Can someone tell me what they are prewired for?
It should be the same as any other F3. Left is heated grips and the right is Fog lights.
2017 F3 Limited
Thank you
