Results 1 to 25 of 25
    Nov 2015
    Tinley Park, Il
    Default rubber grommet mount found
    When I had my spyder up on the jack it tilted and one side went down. After righting it I ground this on the floor. Any ideas where it came from? Thanks, Mike PS everyone get out and ride
    Aug 2013
    SF Bay Area
    Any loose panels?
    2021 F3 Ltd , Magna Red
    Nov 2015
    Tinley Park, Il
    None that I has noticed. Man you've been to alotta states, how'd you miss Ohio
    May 2017
    Mesa, Arid-Zone-A
    Check the panels next to your knees. Those two "false" fasteners actually have a tab that protrudes into a grommet. Often times that grommet will dislodge when the panel is installed. Push on and release each of the false fasteners to see if they are tight, or loose. Easy to tell. Not a real big problem if the grommet is not there..... Jim
    Semper Fi
    Aug 2013
    SF Bay Area
    40 years of riding MC's. Once of the events I've attended was in Louisville. Went all the way across on 80 then checked out Tenn. while I was there. Then went east and up through NY and back across Canada. 3 weeks, 8200 miles. Just kinda missed it.
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    That came off your Tri-Axis Handel bars.
    Ride safe!
    2022 Sea-T0-Sky
    Sep 2014
    USA
    Top of the handlebars in the middle
    Aug 2013
    SF Bay Area
    No it's not off the Tai-Axis bars as the small rubber plug doesn't look anything like what is pictured.
    What I see pictured it what would come off a panel and push into a grommet. Could be one of the pins on the panels that are next to the knees. You see 2 screws on each side and they are fake as they are what hold the pins in place. If one is missing it wouldn't affect the panel as they are a very tight fit.
    Sep 2014
    USA
    No. Its not one of the pins on the side they are one pin each on the side that plugs into the grommets
    Nov 2015
    Tinley Park, Il
    t
    THANKS EVERYONE, i HAVEN'T FOUND ANYTHING YET, BUT NEXT TIME SHES UP IN THE AIR i'LL CHECK EVERYWHERE.
    May 2013
    Edmonton Alberta, Canada
    This is the rubber cover for the center adjusting nut on a Tri-Axis bars, I had that same piece in my hands today...
    2014 RT-Ltd , Cognac
    May 2013
    Aug 2013
    SF Bay Area
    Ah, OK. I've never pulled it all the way off. I just lift up to lower part and make adjustments. The image doesn't help with size. Looked bigger.
    Nov 2015
    Tinley Park, Il
    Default rubber grommet mount found better pics
    Here are a couple of better pics. Thanks, Mike
    Feb 2012
    Spring City,Utah
    I don't know where that does go but I do know it is not one of the grommets under the side panels as those are large rubber o rings that the pins in the side panels fit into.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2014
    USA
    Post #12 is where it suppose to go.
    Or post a pic of your handlebars like in post #12
    Florida Swamp
    One of your friends was there while you was working on it and had a strange looking piece in his pocket. He slipped it under the bike to confuse you and he is sitting at home laughing his ass off right now.
    2019 F3-S , Black & Silver
    Thinks out loud
    Apr 2012
    Quote Originally Posted by Gwolf View Post
    Always a prankster in the crowd Another good one for the summer is turning your buddies heated grips on and watching him 'HOT HAND' it until it finally dawns on him.
    Jun 2019
    jstreet
    The heated grip I did to myself... Riding back from west side of Oahu.. With gloves... Man did my hands get warm... I finally looked down.. Yup, I did it to myself... If nothing else, they work great... Not recommended for Hawaii.. Lol....
    2012 RTS SE5 , Spider Web Brake pedal Orbital blue
    Nov 2015
    Tinley Park, Il
    Yeah, probably my wife
    Florida Swamp
    Quote Originally Posted by Jeriatric View Post
    If the one who did it is riding a Japanese bike, you can get even by pouring a pile of rice under his bike, then point it out to him and tell him it is leaking.
    Nov 2015
    Tinley Park, Il
    Default Founder rubber piece
    Found 2 better than pics, its not from the handlebars I have the triaxis bars
    Mar 2013
    I believe that is from the OEM bars. It covered the place where the GPS mount goes. Most likely fell out when the Tri Axis bars were installed.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2015
    Tinley Park, Il
    Thanks everyone
    Sep 2014
    USA
    I checked this morning on mine that is off the TRi Axis bars.
    Well anyway good luck!
