Results 1 to 8 of 8
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Default Maintenance reminder?
    I'm Going to change the oil in our 2019 RTL in the next week or so. Is there any type of maintenance "service" reminder that needs to be reset?
    Most new cars you need to reset some type of service reminder after an oil change.
    Obviously this isn't a car ...but it is the first modern motorcycle I've changed the oil in.
    Thanks in advance!!
    P.W.
    western Colorado
    In owning 3 spyders I’ve never seen a reminder come up. Dealer says they reset in computer. I use to do every other oil change my self.
    Default No such thing....
    Not on these machines...I pin up a reminder in the garage where visable and go by that...
    ​2012 RS sm5
    Mar 2018
    IA
    Thanks for the info.! I didn't think there was, but wanted to make sure....
    P.W.
    Jun 2016
    indpls in
    i use the b trip so i can keep track
    Jul 2014
    Mint Hill, NC
    I stick a small piece of paper with the mileage due point on it in the glove box because I regularly use both A and B trip odos.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Apr 2019
    Florida Swamp
    I don't change the oil or do the service at the recommended times in the manuals. It just seems way too long and I have never run a bike that many miles between oil changes. I went right back to the same easy to remember schedule I have been using for over 50 years. Did the first service at 2,500 and then every 5,000 miles after that. I realize these are air cooled. That and some other factors would make the oil last a lot longer, The Spyder is the first water cooled bike I ever owned. Still, it does not hurt a thing to change the oil and filters about twice as often as they recommend, and the service interval is easy to figure in your head.
    2019 F3-S , Black & Silver
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Quote Originally Posted by P.W. View Post
    Thanks in advance!!
    P.W.
    FWIW......I use notes in my phone to keep track of everything regarding the Spyder, and my other bikes(one note folder each). Date, mileage done or date and/or mileage something needs to be done. Right down to when I last checked tire pressure. Sounds crazy, I know. Until you wish you could remember when you last did this or that. Like I said. FWIW
