Results 1 to 13 of 13
    May 2009
    Connecticut
    Default Front Sprocket Slight wooble in air!!!
    https://youtu.be/aP9JX20dog8
    Checked my F3 belt tracking today because it was settling more toward the middle of the rear sprocket instead of close to the sprocket like before.
    ANYWAY at idle jacked up it tracks great and I only have 16,500 miles - My belt tension is 140 jacked up which is fine for me BUT the front sprocket wobbles slightly like the video above and The red dust has been very little since I retorqued the New bolt a year ago. Is the slight wobble normal because its in the air with no load on it or is the Sprocket getting ready to go. Anyone have experience with the slight wobble?
    Sea Doo GTI-SE 90 Jet Ski!!
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    I don't know of any case where wobble on a gear or sprocket is normal.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Quote Originally Posted by Grandpot View Post
    ……….. I think the clearance between the sprocket and the shaft should be very, very close to zero …. and from what I've read about the RED DUST thing …. the only amount should NONE …… good luck …. Mike
    Dec 2013
    Is there really any wobble in the sprocket, or is it just slight manufacturing deformities making you think it's wobbling? I'd be checking the sprocket pretty carefully before doing anything else, but like others have said, there shouldn't be ANY wobble in the sprocket, and the only acceptable amount of 'red dust is NONE!!
    Good Luck!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Member CaptainHolly's Avatar
    Jul 2019
    SW USA
    Quote Originally Posted by Sarge707 View Post
    Pardon my ignorance -- I'm new to the Can-Am world. I'm looking at a 2015 F3-S SE6 soon. What is this "red dust" that I've seen mentioned several times now?
    Current Motorcycles: 6 BMWs, 1 Kaw, 1 Suzuki
    Greenville Tx
    Quote Originally Posted by CaptainHolly View Post
    The front sprocket has been known to get loose causing the splines to wear. In turn the steel that wears off turns into a red rusty dust. You need to check under the front inspection cover regularly and if you see red dust, it is a sign that you need to replace the front sprocket and bolt. If your Spyder is under warranty, it will not cost you anything but if you let it go too long it can also ruin the shaft and leave you stranded.
    2017 F3 Limited
    Nov 2015
    Chardon, OH
    Sorry Sarge. Not really seeing any sprocket wobble at all. Now, that little out of round look of the bolt flange? Yeah. I would expect that. Just the way the bolt is made, I believe, not being a perfectly machined part.
    Doug
    ”Freedom is not a loophole”
    Greenville Tx
    If you do see red dust, I would recommend retorquing the bolt just to buy you some time to get it in the shop before it gets completely stripped out and spins freely.
    2017 F3 Limited
    Jul 2019
    SW USA
    Quote Originally Posted by AY4B View Post
    Thank you.
    May 2009
    Connecticut
    Quote Originally Posted by Snowbelt Spyder View Post
    Thanks- Just what I wanted to hear. The YouTube Person responded that the little bolt wobble causes NO problems and The Red Dust has been very little since I retorqued a New Bolt several thousand miles ago. When mine goes I got a New Sprocket and Bolt ready and towing home is covered because I drive local backroads.
    Default Not seeing a problem
    Have found shadows, dust and grime tend to mislead as well as the washer on center bolt is never centered. If you have no vibrations your good...
    ​2012 RS sm5
    SoFlo
    My opinion, remove the pulley and inspect before failure. Not that you are concerned about getting home and such, better safe than sorry regarding the gearbox output shaft.
    As mentioned, the fit is slip fit but with basically no looseness or freeplay before installing the bolt.
    Worse case, you got piece of mind, AND you can clean the splines, then assemble the pulley onto the shaft with lubricant.
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    The best substitute for brains & knowledge is....................silence.
