Results 1 to 5 of 5
Thread: Audio input
    Feb 2018
    New York
    Default Audio input
    Is there a way to run the audio input cable from the back to the front on a 2011 rt
    Apr 2017
    North Central Florida
    I think the proper answer is: IF you have the stock short audio cable to start with, visit an audio store and get a LONG standard audio extension cable with the right connectors on it.
    But a lot of folks have dealt with that and better answers should follow.
    Feb 2018
    New York
    I have the short stock cable. I am using a Bluetooth reciver now.
    Jul 2011
    Mitchell, Ontario, Canada
    Get one of these or something similar. Route it to the front.
    https://www.amazon.com/AmazonBasics-...-1-spons&psc=1
    2018 F3 LIMITED
    Quote Originally Posted by Jay13433 View Post
    If you are referring to the plug that's on the right side ( inside ) of the rear trunk ….. I removed that plug and then took that part of the cable out of the harness …. I then routed it under the Tupperware …. drilled a hole in the right side of the glovebox ( inside ) attached the plug there and use it to connect my Sirius XM satellite …… I have some pics in my albums of the radio cradle …. Mike
