Results 1 to 3 of 3
    Jul 2018
    Germany
    Post always trouble with dynamic light product
    Hi,
    Last year I bought the amber LED brightsides for my spyder - i have the fenders from the newer models..
    Now, i had trouble with the lights for two times, some of the LEDS are broken.
    Is there any possibility to change the SMD or something other inner parts to make them userfriendly...??
    greatings from germany
    Reiner
    2014 STS SE5 , circuit yellow (metallic)
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    SMT led's are usually put on with a machine that passes the PB board under solder and then placed by a robot. If you could find the SMT led's, you might be able to replace them but would be very difficult. Van you contact the vendor?
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
    Jul 2018
    Germany
    Hello,
    when the problem appeared for the first time, i made a reclamation and the seller sent me a new pair of brightsides.
    Now, for the second time i think it is not solution, because i always have to pay freight, custom, tax etc.
    If i get no other idea, i will buy smd`s und change them, but i think the most poular problem is, that the originals from dynamic light are not waterproof.
    R
