Results 1 to 13 of 13
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Default Rivco Double Flag Holder
    Just spent 2 1/2 hrs in the HOT Florida sun trying to mount the flag holders so that the rear trunk will latch. Don't know what the problem was. Everyone says they never had a problem. Finally would up with a metal washer that I had on the bottom, and one of their plastic washers on top. Still have to slam it down very hard to make it latch.
    Bossier LoUiSiAna
    Can’t the trunk latch be adjusted so you don’t have to slam shut?
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    May 2019
    Palm Bay, Florida
    Tried it every way that I possibly could. They use round head screws which increases the height. If they would countersink the screw holes and use flat head screws, it would probably be better.
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by Baron14y View Post
    Did you get the FH400 flag holders? I know one person got the FH450 and had a hard time because they are made for the F3.
    2012 RTL , Brown
    Nov 2015
    Chardon, OH
    Well, that’s a good question. ^^^.
    And Baron, the plastic washers go IN the holes in the body panel below the bracket. The bracket lays flush on the body panel. You will then have clearance with the top of the screws and at the side. The bracket is not resting on a washer. Sounds like you have the bracket resting on a metal washer, so it’s now too high. But yeah, make sure that you ordered the correct one.
    Doug
    ”Freedom is not a loophole”
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Snowbelt Spyder View Post
    Actually, I followed the instructions implicitly, with the plastic washers in the hole. If you look closely, they are too thick and actually sit above the hole. The washer I am using is even with the top of the hole, or slightly below. I then tried various washers in various ways as well as moving the bracket around and trying to adjust the latch. What I described above was the only way it would latch. Why the problem, I haven't a clue. Tomorrow morning I may try again. Of course, my wife will probably kill me for fooling with it again. But, now it is a challenge.
    May 2019
    Palm Bay, Florida
    VICTORY!! I removed the plastic washers from the top and put on a thin washer I had in my stash. Made a small adjustment to the latch. Now, I can drop the lid from 2" and it latches. Yeah.
    Nov 2015
    Chardon, OH
    Excellent. Go show your colors. Just an FYI - If flying the US flag with another different flag, the US flag goes on the right.
    Doug
    May 2019
    Palm Bay, Florida
    I was not aware of that. It shall be changed.
    Nov 2015
    Chardon, OH
    Yeah. I looked it up a few years ago when I got my flag holder. There’s flag etiquette for everything I guess. It’s also sometimes referred to as “parade right”. This site just happens to have a picture. Ride safe. Watch out for deer.
    https://www.flagandbanner.com/flags/...tiquette.asp#h
    Doug
    May 2019
    Palm Bay, Florida
    Don't have to worry about the deer. It's so hot, they are all in the pool.
    Dec 2016
    Port Richey, FL
    Glad you got it worked out. When I installed mine, I had to replace 1 of the included washers with a slightly thinner one to get it to flush up perfectly. Lucky for me, I had a bunch of extra plastic washers in the fastener organizer in the garage. But it wasn't a big problem with the orig ones per instructions, just had to push lightly to make it latch. But I knew that would keep uneven stress on the trunk lid/latch and it created a slightly noticeable cant at the seam between lid and trunk (wider on 1 side than the other). It's been perfect since I swapped that 1 washer out.
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Musashi View Post
    I'm sure glad it wasn't just me.
