Results 1 to 10 of 10
Thread: New Dash
    Active Member ris's Avatar
    Jun 2016
    N.H.
    Default New Dash
    I have a 2015 RTSSE6. Had to have a new dash (instrument cluster) installed. Does anyone know how to reset the mileage on the new dash to reflect what was on the old one before the change. Thank you in advance.
    Default Oh oh.....
    Not sure about the new ones but from the past there is no way to set the mileage. You have to keep a record of when and at what mileage you replaced the dash. The only information that will carry over is the hours of engine operation. Must come from the interrnal computers.
    ​2012 RS sm5
    Jul 2014
    Mint Hill, NC
    There is no way that I know of to update a new dash cluster with the mileage of a replaced one. As Gene said save the dealer invoice for the change that should have been listed from the old cluster. You will need that info when selling the Spyder.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    with posts #2 and #3
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Mine's the same way - dealer replaced it before I bought it. Its at around 1400 miles now, but there's over 30k on it.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Active Member mmmdowning's Avatar
    Dec 2017
    Virginia
    This is true, I just had mine go out and replaced 2 weeks ago on a 2016 RT-S. All you can do is keep your work order receipts for if you resale it.
    2020 RT Limited SE6
    2016 RT-S , white
    Aug 2019
    Douglasville GA
    A little off topic but useful information. My dash was giving me all kind of indications, parking break, check engine light, and every other one available, it was random and usually when going thru bumps,it would also randomly reset itself, the Spyder was working great so I knew this was an indication problem. I removed the dash and found several cold solder joints on the circuit board main connector, I fixed it myself since I work on electronics, before buying a new cluster, take the faulty one to a electronics repair shop and ask to resolder the main connector, you may be saving a lot.
    2012 RT , Break pedal extender Silver
    SoFlo
    Quote Originally Posted by edduyn View Post
    Noticed you recently joined Spyderlovers. FWIW, the cold solder joints failing seems to remain as an ongoing issue. Years ago another owner found exactly the same as you did. Repaired the solder connections and went on without further issues.
    Jun 2015
    Hampton Roads, VA
    According to the site, BUDS (premium or whatever) can reset or change everything. There are two levels of BUDS license regular and whatever they call "pro" or factory. Most shops just have the regular. If you Google BUDS license for can am you can find it on amazon, for like $1400
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Quote Originally Posted by stevencovert View Post
    Well … maybe … but, in most states, it is illegal to tamper with an odometer and doing so can get you in big trouble. This may even be a federal rule. Bottom line, just keep your receipts and a record of the mileage when the dash cluster was changed.
    All the best …. Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
