Results 1 to 7 of 7
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Default RLS exhaust - Coated original cat
    RLS exhaust offers a stock cat with coating to cut down on heat - Does antone have that on there RT ? I'm extremely happy with my RLS exhaust Punisher muffler and orginal cat pipe , one drawn back is the heat that is generated almost unbearable at 100 degree Iowa swamp weather. Looking for thoughts on coating the cat with ceramic....thanks
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Nov 2018
    Waynesboro, PA
    I'm waiting to see if anyone gets the coating done on their converter and if it works or not also. 400 degree drop in temperature sounds like a lot, but not be much of a difference in the feel. Sometimes hot is hot 600 or 1000 their both hot. So I'm in the same boat as you waiting to hear from others whom have used the coated cat.
    2012 RTL , Brown
    Active Member RLS Exhaust's Avatar
    Mar 2019
    Waxahachie TX
    this is the product that i use on my exhaust and cat deleteshttps://www.cerakote.com/finishes/C-...glacier-black/
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I'm curious why you still have the catalytic converter. Maybe in that weird state, California, but everywhere else, a cat delete pipe is called for. Significantly less heat. Significantly. My converter was removed and a cat delete pipe at Pittbull
    Motosports in Springfield installed in the first 1000 miles. And 39k later, no adverse effects.
    Oct 2015
    Iowa
    I understand - I love the way my Spyder sounds with the cat pipe on it - in my experience the sound is changed drastically .
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Mar 2019
    Las Vegas
    I bought a cat delete pipe and had it ceramic coated. I am waiting on my first service to be done this Friday before I install it.
    I may also remove the exhaust pipe that runs between the cat and the header and coat that one too.
    2018 RT Limited White/Chrome.
    BlueSeaSky front & rear dash cam.
    USB plugs
    TechMount cellphone holder
    Squared Away laser alignment.
    BajaRon anti-sway bar and links.
    Dynojet
    Ceramic coated cat delete pipe
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by Kredab View Post
    Quiet is good.
    2012 RTL , Brown
