Results 1 to 5 of 5
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Default Rear trunk lift support
    I have a rack on top of the lid and now, will not stay up. I have to prop it up. Do you think that it is just too much weight for the lift support, or that the support has lost some of it's ability?
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Several threads on this. Here is the latest.
    https://www.spyderlovers.com/forums/...ht=trunk+strut
    Aug 2016
    Cleveland, Ga
    I took the compression spring off and went to the hardware store and got 2 stiff springs that fit over the shock. Unscrew the clevice off the rod to get the spring on. It took 2 springs to get the length I needed. It works great and only 2 or 3 dollars.
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    I just added another shock to the other side of the lid, works perfect!
    2014 RT-Ltd , Cognac
    May 2019
    Palm Bay, Florida
    Just found a paint stick, cut it to length, wife painted it white, does a great job for as often as I go into the rear trunk. Total cost (not counting the stick...have no idea what that cost if anything), about $.02 for the paint.
