Results 1 to 13 of 13
    Jun 2019
    Florida
    Default Rear Shock adjustment tool ?
    Does anyone know the part number for the rear shock adjustment wrench for 600 Ryker ??
    Apr 2019
    Kansas
    Funny how the owners manual doesn't even mention how to adjust. Guess they take for granted you already know. With that said, you should be able to use just a pair of channel lock pliers or possibly a strap wrench. I you can get the rear in the air you can probably turn it by hand. The real tool is called a spanner wrench and you should be able to pick one up at any cycle shop.
    Jun 2019
    Florida
    Thanks for reply, I’m fully aware of what’s needed, I was wondering if there was a specific one needed since the ” 4” I have from previous bikes don’t fit the shock in question. And I really ain’t going to use Channel lock pliers on a new bike !
    Nov 2018
    N.E. Ohio
    I know this has been discussed before. Try a search and it will give you a parts number. cueman
    Jun 2019
    Florida
    Quote Originally Posted by cueman View Post
    Thanks , I did that 1st, did not find any #######.
    Nov 2018
    N.E. Ohio
    I just did a search for “Ryker shock spanner” and 3 different discussions came up. Give this a try. cueman
    Apr 2019
    Kansas
    Well, the one's from a Yamaha fit perfect on a Rally shock
    Jun 2019
    Florida
    Quote Originally Posted by KC61 View Post
    Rally shock is not same as standard Ryker shock. The ones I have from my Yamaha R1 and my Yamaha FZ09 won’t work.
    Mar 2019
    Pennsylvania
    Insane, check out my post on Ryker 900 shop talk. It’s a Progressive783 scanner purchased on amazon. It works great!
    Jun 2019
    Florida
    Quote Originally Posted by poconoscooter1 View Post
    Thanks. Just ordered.
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Finally a straight answer
    2022 F3 Limited , Monolith Black / Dark
    Nov 2018
    Virginia
    I used this and a ratchet. It's a bit fiddly but it works.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2018 Can Am Spyder F3L, 1995 BMW R1100R, 1988 Suzuki GS250, 2019 Ryker 600 (Wife's)
    Jun 2019
    Florida
    Quote Originally Posted by Bob204bc View Post
    Thats what I ordered off eBay.
