after 5.000 miles I lost the air on one of my front Kendas - my neighbor could help me, I still have no repair kit with me, what would you use for that problem ??
Looks like you have a plug kit, that’s what I would use.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
IMO, a properly installed plug should work OK. If you believe it’s not satisfactory this would be a good time to replace both front tires for a better quality set. cueman
From all that I’ve been able to find no one makes another tire the size needed for front. Enlighten us if you have.
Your friends repair is good but the inside patch would be better. To avoid all that the mushroom plug kit is the best in my opinion and has worked for me without having to go the inside plug or rebalancing route ...
Would Ride-On work to solve both problems? Seal the puncture or plug in this case and balance the wheel/ tire. Also act as a flat prevention.
Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
