Results 1 to 25 of 27
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Default Headlight issues on 2014 RTL
    Anyone know the Bulb life expected and the warranty period of TRIC-RT-LEDHG ?
    We just noticed last night (We don't usually run at night at all) that my left front headlight isn't working.
    I installed TRIC-RT-LEDHG bulbs (ordered from Value-Accessories) in mid-January of 2018.
    Mileage since then is approx. 9,000 if that helps.
    I "thought" I had kept the old factory bulbs (which were working at the time) but right now I can't find them or the installation instructions.
    Also, the only info I can find about the original BRP bulbs is "H4 - 60W", but there appears to be a whole family of H4 bulbs in different configurations on the web.
    To replace in a hurry, what bulb specs/model would I buy at - say "OReilly's ??
    Input appreciated.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Jun 2019
    Canuckistan
    Quote Originally Posted by teninospyder View Post
    Input appreciated.
    Howdy;
    An H4 is an H4. It's an industry-standard base (also known as #9003 / HB2).
    https://en.wikipedia.org/wiki/List_o...ght_bulb_types
    Hence - any Sylvania, Osram, Philips, etc halogen bulb at yer store will fit. Always replace in PAIRS. Always use OEM-specified wattages. Use of the 80w/100w variants WILL do damage.
    Here's a list at O' Reilly's: https://www.oreillyauto.com/search?q...Headlight+Bulb
    Fer install instructions - it's in the manwell, starting on page 151 - available here: http://www.operatorsguides.brp.com/I...4-f9aacd912fc1
    PS - you've discovered the reality of poorly-engineered, cheap LED aftermarket crap, lol
    Cheers
    E
    A pair of Sylvania 9005 bulbs are in fact H3s. FWIW, for the time involved to replace just one do both at the same time as you must remove the front fascia. For the upper center 10 mm bolt on each headlight assembly hold the bolt in the socket wrench with a small piece of painter's tape (tip courtesy of Ann Meyer of Squared Away) or a small dab of dielectric grease. Note which hole the adjusting cable is mounted in before you remove it; it is probably marked with a colored grease pencil.
    Jun 2019
    Canuckistan
    According to the 2014 RT manual, it specifies H4 (9003) for headlights.
    9005's are HB3's. And not anywhere the same as an H3.
    Cheers
    E
    Mar 2015
    forrest above Reno, Nv
    9005 style bulb is the correct one for '14 and later 's.
    The 360* LED bulb from " the company that cannot be mentioned" is a great bulb. Cindy at the previously named company replaced an older model LED that failed-- no questions asked!!
    2014 RTS , Circuit Yellow
    Jun 2019
    Canuckistan
    Quote Originally Posted by Lew L View Post
    Howdy & thankee fer that.
    For headlights? The allegedly-current online 2014 RT Owner's guide is incorrect, then? Sheesh... who woulda thought, eh?
    Still - it sure ain't an H3, lol!
    Hedging my bets - here's a list of O'Reilly's 9005 / HB3 halogen bulbs.
    https://www.oreillyauto.com/search?q=9005+bulbs
    Cheers
    E
    EDIT - PS - a 360 deg LED bulb is a physical impossibility - IF you want to actually effectively heatsink the emitter. The heatpipe/substrate will Always shroud the LED to some degree. Unless it's some sort of Alien Tech? In that case, I'm in, lol! BTW - got's a pic of this unicorn? I'm always up fer learnin' sumfin' new.
    EDIT - PPS - WTF's the dealeo here with all of this "Vendors that shall not be named" stuff? Seems counterproductive to me. Give, fellers - even a Reader's Digest version, lol!
    Sep 2014
    tenino, wa
    Interesting you consider the TRICLED bulbs to be "poorly-engineered, cheap LED aftermarket crap" (??)
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Mar 2015
    Said owners guide has been wrong before...........
    But I'll check again.
    Quote Originally Posted by Entropy View Post
    Cheers
    E
    WELL THE MANUAL IS WRONG !!!!!!! …………….I have an RT 2014 and the bulbs are 9005 or HB3 !!!!! ….. Mike
    Mar 2015
    Checked a different source ( Lamonster ) -------
    Again--- the 9005 is the correct headlight bulb for a late model spyder.
    Jun 2019
    Canuckistan
    Yep. Sorry.
    Almost ALL of the cheap ( and hugely marked-up) garbage being peddled start by throwing the Emitter Manufacturer's Reference design specification for power input, safe output, heatsink requirements, power supply requirements... and THROW it out the window.
    To be replaced with all the various ridiculous, compromised (for the sake of bling, marketing and profit) POS designs being sold to the poor masses. Specs are bogus, lifespans rating are bogus, product testing & reliability is non-existent - even the color spectrum and CRI is wrong for intended use.
    Most don't care / won't listen / don't know enough to question or measure all of this for themselves. For me it was my life.
    I sure don't lose any sleep over it, lol. I mean, 100,000 flies simply CANNOT be wrong, eh? lol
    Carry on.
    Cheers
    E
    Jun 2019
    Canuckistan
    Outstanding. Quick - Someone tell, BRP, lol. And the OP.
    And it STILL isn't an H3... lmao !!!
    Cheers
    E
    Mar 2015
    OH ----BTW,
    I think that TricLED 360* LED's are made just fine. I've put aftermarket leds in all my vehicles but I don't buy the cheap ones. You do get what you pay for.
    Lew L
    I had put TricLED LED bulbs in my 2014 RT-L at SpyderFest 2016.
    My dealership called me about a Month ago, and wanted to know where I had bought them: one of them had stopped working, and the current owners of the bike needed a replacement.
    By the way: I'm glad to see that their name is no longer being censored in here... Thanks!
    There seemed to be a problem with the bulbs on the 2014. I replaced the OEM bulbs twice in two years. Of course, only one burned out at a time.
    I changed to TriCLED, about three years ago. I have NOT had a problem since. The OEM's were NOT LED bulbs.
    Mar 2015
    I hope this doesn't start another oil type, tire brand, tire air pressure war.
    "By the way: I'm glad to see that their name is no longer being censored in here... Thanks! "
    Jun 2019
    Canuckistan
    War? For sharing hard-won experience with other fellers? Nupe - I've no need fer that nonsense. Not my eyes, my bike, my money, or my life. Folks can go find all of this public-domain factual data all on their own. But they won't. Mass myopia tends to be the norm. Tough - for them.
    Fact - LED's have been commercially available since the late 60's / early 70's. Which is how long I've been involved with them. The fundamental Physics and constraints were established looong ago. A fancy box and slick sales verbiage does not change that one iota.
    Cheers
    E
    Many members felt the same way. It was worked out behind the scenes.
    The 2014 operator's guide has far more than an acceptable number of errors in it, not the least of which is the number for the headlight bulbs. I took the number off the burned out bulbs which were Phillips brand. Never buy a halogen bulb from a Can Am dealer because, in addition to costing more than ones from an auto parts store, the OEM replacement bulbs are not in a sealed package like the auto parts store bulbs so you never know if a greasy fingered parts guy has handled them before you showed up.
    ……...however, I have learned to clean all halogen bulbs with Alcohol before using them …. and use thin gloves when putting them in......jmho … Mike
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    I have one working Tricled LED headlamp from the April 2018 time frame that may match yours. I have been saving just for a case like this. If you want it, you can have it for shipping charges only. Here is a picture. PM me if you want to give it a try.
    Sep 2014
    USA
    Contact Tricled. They have excellent customer service on there items even though you purchased from another vendor.
    Sep 2014
    tenino, wa
    To ALL actually helpful parties.......................In response to an email info request I submitted on their website, Cindy at TRICled has already emailed me back and will contact me next week.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Sep 2014
    USA
    CE models High Beam: Halogen, 2 x 65 W (type H9) Low Beam: Halogen, 2 x 60 W Headlight
    Headlight Other Models Halogen, 2 x 60 W (type H4)
    Not sure if this is considered helpful?
    Mar 2015
    Cheers
    E
    Here ya go:
    Here is the quote from the tricLED website.
    " Our LED headlight has an all new 360° light output and this creates zero darkspots unlike LED's with only a 2 side output."
    It looks different than other headlight LEDs that I've seen and they work great.
    For a few months the tricLED company had some " differences" with the owners of the site and was not allowed to have its name displayed, but the site users tried to get around the administrators ban. But all is better now.
    Lew L
