Results 1 to 8 of 8
    Apr 2017
    Queensbury, NY
    Default Another TIre Question...
    The front (stock) tires on my 2016 F3-T have about 13,700 miles on them right now, so I expect to have to replace them fairly soon.
    Last year, I replaced the rear tire with an Altimax. So now I'm looking for recommendations for replacing the fronts - Should they match the rear tire, or would you suggest something else?
    Thanks!
    Bert
    Aug 2007
    Greeneville, TN
    They do not have to match. Look at your options and get the best tire you can. But most fronts last 20~25k. Are your sure yours are ready to be retired? (No pun intended...)
    Default choices, choices
    Once upon a time there were little to pick from.... but now you can search here or tire stores and find a large assortment of tires being used. I do you have time left as that is low mileage even for the Kenda.
    ​2012 RS sm5
    I'm lazy this AM ….. use SEARCH … type in Vredestein tire ….. you will get a lot of info from an expert and actual users from this site …… your welcome …. Mike
    Nov 2012
    North Las Vegas, NV
    On our 2016 F3L I'm using Federal Formoza AZ01's in the stock size at 20 psi and the rear is a General Altimax. They work well together.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Apr 2017
    Queensbury, NY
    I haven't given them a close inspection yet. It's just that I thought I read somewhere that the stock Kenda's usually only last 10-15K. So, I posted my question.
    Bert
    Apr 2017
    Queensbury, NY
    Good to know ... I'll keep that in mind.
    Bert
    Apr 2017
    Queensbury, NY
    Thanks, Mike!
    Bert
