Results 1 to 25 of 33
    Active Member Baron14y's Avatar
    May 2019
    Palm Bay, Florida
    Default Laser wheel alignment
    Spyder felt kind of squirlly so took it in to have the wheels laser aligned. They checked things out and said nothing needed. Reset the computer, and didn't charge me a dime. Now, I'm thinking to change out the front tires from the Kenda's (yuk) to General AltiMax RT43's, or Federal Formoza or SS657 in the 185/60R14 size. Any comments yea or nay?
    Nov 2018
    Claremore, Ok.
    I bought the Federal Formosa AZ01 (stock size) from WalMart on line ($58.00 ea.). Had to wait a few days for them to be shipped to my local store. Then took them to my favorite tire dealership to have them mounted and spin balanced. They stick to the twisties like they're glued. I love them, especially compared to the Krap-da.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Revalden View Post
    How are they in the rain (it sometimes rains here in Florida)?
    May 2017
    Mesa, Arid-Zone-A
    Having the alignment within BRP specs is not the same and usually not as good as a laser alignment. Getting rid of the Kendas is one of the very best things I did to improve my ride. I went with Federal Formoza AZ01 175/55R15s. Excellent handling tire. As far as rain, well, I live in Arizona so can't help you there. I believe SpyderAnn has the same tires and reports good things about it's handling the rain. Good luck..... Jim
    Semper Fi
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by canamjhb View Post
    Having the alignment within BRP specs is not the same and usually not as good as a laser alignment. Getting rid of the Kendas is one of the very best things I did to improve my ride. I went with Federal Fermoza AZ01 175/55R15s. Excellent handling tire. As far as rain, well, I live in Arizona so can't help you there. I believe SpyderAnn has the same tires and reports good things about it's handling the rain. Good luck..... Jim
    You show 15" wheels. My fronts are 14".
    Nov 2015
    Chardon, OH
    Your bio says you have a 2015 RT Ltd. Unless you’re asking about a different machine, your fronts are supposed to be 15”.
    Doug
    ”Freedom is not a loophole”
    May 2019
    Palm Bay, Florida
    You are absolutely right. That's what is on my Spyder. See what happens when you are 78 and don't have your reading glasses on. But, what's 1" among friends.
    Nov 2015
    Chardon, OH
    Well, now that you’re looking for 15” tires, it changes the landscape quite a bit. More choices.
    Doug
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Baron14y View Post
    I just ordered the Federal Formoza AZ01's, in 175/55R15. Also just ordered a BajaRon sway bar. Hope to have everything put on next week. Should ride like it is on tracks. Will let everyone know how it feels (assuming anyone is interested).
    May 2017
    Mesa, Arid-Zone-A
    When I changed my front tires I noticed the fender bolts protruded unnecessarily into the wheel area. I didn't think there would be a problem of rubbing the tires but just to be safe, I pulled each bolt out, one by one, and snipped about a 1/4 inch off each one with a bolt cutter. It was a quick and easy thing to do. Took maybe 10 minutes. If I remember right there are 3 bolts for each side. Once you remove your wheels you will be able to see what I am referring to. Necessary....? Probably not. But I just didn't like the looks of those bolt ends protruding towards my tires. Good luck..... Jim
    Semper Fi
    Jun 2010
    Las Vegas
    The Formoza’s are awesome in the rain. I also run them in the stock size.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2018
    Waynesboro, PA
    Make sure and lower the air pressure in the new tires to about 16-18 max psi for best results.
    2012 RTL , Brown
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by CopperSpyder View Post
    A lot of people have said that. Will do.
    May 2019
    Palm Bay, Florida
    I just noticed that you hadn't ridden any of your Spyders to Hawaii. How come, too far to ride?
    May 2019
    Palm Bay, Florida
    Reset the pressures to 18 front and 24 rear. The fronts were fine, but the rear (Arachnid) felt like it was trying to steer the machine instead of me. Going to put it back to 28 psi.
    Jun 2010
    Las Vegas
    Instead of changing the pressure in the Arachnid I would put on a better tire.
    2010 RT- 622
    May 2019
    Palm Bay, Florida
    Yeah, good idea. However, I've spent a good junk of $ already on things so, unless it really sucks and I can't make it better, will stay with the Arachnid for a while. Still a lot of tread on it.
    Member jakeman66's Avatar
    Jun 2019
    Norfolk, VA
    Did you take the bike to your tire dealership or did you remove take just the wheels? thanks.
    2019 F3L , Pearl White
    Sep 2014
    Scotland
    Good idea. Running a tyre too soft is always a bad idea, more wall flexing, more tread squirming, less tread base control, more heat build up, more tread side wear, poorer aquaplaning resistance. To name just a few bad reasons... .
    If putting it back to 28psi makes a marked difference, it might be worth trying 30 and 32. Perhaps the tyre is a bit too flexi.
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Spyderlass View Post
    I think I will split the difference, and go to 30 to see how it feels. If it wears the tire out more quickly, that is a good thing. It will justify spending the $ to get a good tire on the rear.
    Sep 2014
    Scotland
    Normally, a slightly high pressure will result in better mileage because, to some extent, it prevents the tread blocks squirming. The exception to this is where the wheel is a little narrow for the tyre width so the tyre tread becomes slightly too convex so wears the centre a little too much. And, IMHO, that is part of the issue with the Spyder rear tyre.
    May 2019
    Palm Bay, Florida
    Just put 30 in the rear Arachnid. Feels really good now, and that is riding on, arguably, the worst major road in the county, if not the state. The only place there aren't potholes is where there are filled potholes. The front Federals are at 18. I am going to try 20. If no difference, back to 18.
    Jul 2019
    Melbourne Florida
    When are we riding Baron? 32907 here.
    May 2019
    Palm Bay, Florida
    Quote Originally Posted by Miesterbro View Post
    I'm in 32909. Always young is in 32901. We should all try to get together to ride and tell war stories.
    May 2019
    Palm Bay, Florida
    Took the Spyder out yesterday to see how the 20 psi in the fronts. GREAT. Maybe it's the way my machine is set up, maybe I have a very sensitive butt, but, going to the lower pressures that many have advised just doesn't feel comfortable. 20 in the front Federal Formoza's, 30 in the rear Arachnid.
