Results 1 to 10 of 10
    Active Member 2013REDRTS's Avatar
    May 2016
    Central Indiana
    Default Air compressor out again
    I had the compressor replaced under warranty once and now it's out again. Is there a better replacement out there? I'm just putting air in under the seat but not sure what pressure for 2 up riding. Thanks
    2013 RED RT-S SE-5. Nothing special, but it's mine. I call it El Diablo Rojo
    US ARMY Combat Engineer. Sapper Strike!
    Active Member kamper's Avatar
    Apr 2016
    Elkton South Dakota
    get the viair version that is on ebay. Cheep and quiet.
    Quote Originally Posted by kamper View Post
    ……….. but just doing it manually ( make sure it doesn't have a leak ) isn't a big deal, the Bag seems to hold pressure pretty well ….. Mike
    Feb 2019
    Portland, Oregon
    Digging through the SL archives, I found this gem. Being frugal (aka cheap) I like his approach to the problem.
    blob:https://www.youtube.com/5cec009c-628...d-18864ffdbbd8
    I tried the link and found it leads to nowhere. So sorry. The video shows a fellow had removed a non working air compressor and removed the motor housing to discover the brushes were stuck in their channels and not touching the commutator. He cleaned out the channels, lubed the end bearing, re-assembled it and it tested out perfect. A man after my own frugal heart. It's nice to know the compressor is serviceable.
    Jun 2010
    Las Vegas
    Very easy to bypass the compressor. Also, in the Owners Manual there is a picture of a label that has the suggested psi for the air bag based on rider weight and gear
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Here's a YouTube video for the complete process including needed parts. https://www.youtube.com/watch?v=5NR_LY7u8eY
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Feb 2012
    Spring City,Utah
    This is a very good step by step video on removing your panels. Your owners manual will also take you thru a step by step removal.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Don't see one on Ebay.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Northern Kalifornia
    Quote Originally Posted by SteveandBelinda View Post
    https://www.google.com/search?source...=1570556071314
    Sep 2017
    Durham,Maine
    Like 911 said, it's a lot cheaper to gut it and fill direct to the bag. You will not miss the compressor a bit, once you figure out what pressure works for you! Good luck!!
    2012 RTL , Pearl
