Results 1 to 12 of 12
    May 2012
    Southern California (Oceanside)
    Default LED running lights on Fr. Fender
    Is there a simple way to replace the front fender running lights to LED. If a simple bulb replacement does anyone know the correct number?
    Bossier LoUiSiAna
    Some years . What is your model & yr??
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    May 2012
    2018 rt
    Quote Originally Posted by Thopper View Post
    2018 rt
    If you have the OLD style fenders ( no ridge on top ) like me ….. they are T10 LED size ( to replace halogen ) ….. I just bought a ten-pack ( amber color ) on e-bay for $1.25 - delivered ….. Mike
    May 2012
    My RT is not a limited so I have the fenders with the little grove in them not the ridge. I am assuming I need t take the fender off to replace the bulb?
    NO NO NO …..( you can access it that way if you don't mind all the work ) …. those fenders take the T10 led amber or white , your choice …… the clear plastic cover comes off ….. push / slide up from the bottom ( it really takes pressure to do it ) so the prong comes free , then wiggle it off …. there isn't much slack for the wires, so gently pull it out …. grasp the socket and twist ( counter -clockwise ) it will come free of the holder …. pull bulb out … re-place ….turn power On …..if it's an LED you may have to reverse the bulb for it to lite …. good luck …. Mike
    May 2012
    Thank you for the response. what do you mean reverse the bulb?
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    remove bulb make a 1/2 turn and reinstall it
    2022 F3 Limited , Monolith Black / Dark
    Quote Originally Posted by DriftersWay View Post
    As stated above ….. this changes the polarity, which will make it light up …. Mike
    May 2012
    Geez I tried pushing and sliding...no luck. The entire light (rubber gasket and all) are trying to move. I assume I a just trying to get the plastic to slide out but not having any luck. Tips?
    I think there is a pic of the process in your owners manual …. There are two prongs (?) …. the lower one is fixed … the upper one has just a bit of FLEX …. when you push up ...the upper one moves a little ….. They are difficult to re-move ….it is the BRP way of building things …. I'm surprised they didn't put LokTite on it also ...………… Mike
    May 2012
    That's funny...I will keep trying.
