Results 1 to 22 of 22
    Jun 2019
    Kansas
    Default Removing RT limited foot pegs
    I’m trying to remove the foot pegs on my wife’s 2012 RT limited so I can install some floorboards I got her for her birthday. I have it raised up on ramps, but it seems like they used a gallon of locktite on the threads. It seems that if I cut off the outside half of the peg off, I can get an impact wrench on the nut. Any help would be appreciated. We are newbies. Mine is a 2013 RT S. Thanks so much.
    Jun 2019
    jstreet
    Default Foot pegs removal
    Quote Originally Posted by DingerD View Post
    I have 2012 RT SE5, am new to this bike but not new to working on bikes...
    Try spraying Liquid wrench. Any hardware or automotive shop should have it. Comes in small or large bottles... Does not take much.. also comes in spray... let sit for 5-10 min try removing again.... Cutting the peg may not be the best idea... If you think any chance of selling or no longer like the floor boards.... I went to remove the antenna, nothing I could do to get it loose...
    I used liquid wrench, was a bit tight but then it came loose.... use extension for more leverage..
    Be sure you have the right size tool... do not want to strip it...Good Luck, just so happens I will install running boards this weekend....
    2012 RTS SE5 , Spider Web Brake pedal Orbital blue
    Bossier LoUiSiAna
    Avoid cutting, your floorboards may require some of that hardware
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jun 2019
    Kansas
    I saw a youtube video of a man who used a small torch to heat up the screws on an F3 to remove two screws on footpegs on that bike. Is that the treatment to loosen the Locktite?
    I don't know how your Floorboards are constructed ….. however I think you can just un-bolt the Peg pads and put the floorboards on to the peg and re-bolt ….. I made my own from diamond plate alumin. and that's how I did mine ….. Mike
    Jun 2019
    Kansas
    Thanks, Mike. These floorboards call for the removal of the entire peg.
    Bryant, Arkansas
    the heat will soften the locktite. DONT START A BARN FIRE, BE GENTLE
    Cruzr Joe
    Jul 2014
    Mint Hill, NC
    Try a heat gun vice a torch; use a 1/2" drive breaker bar.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jul 2010
    Las Vegas, NV
    Much safer idea. The locktite they use can be tough. Good call, Jay!
    Joe Meyer
    Jun 2019
    Kansas
    Thanks gentlemen. Off to Lowe's I go to find a heat gun!
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Mar 2015
    forrest above Reno, Nv
    I have the higher priced one------ has worked great for years.
    2014 RTS , Circuit Yellow
    Heat Gun ….. It will RUIN the paint !!!! …A decent soldering iron used ON the Bolt probably won't …... A BOLT / Thread loosener, not likely if you wipe it off after using, just don't wait to long …… jmho …. Mike
    Nov 2018
    Waynesboro, PA
    On the 2012 RTL there are locking tabs on the back side of the foot peg bolts that you have to bend down before you unbolt them. Make sure you do that. you will need to get under the thing to see them. On right side, there is one bolt that is long that you will have to wiggle a little to get out because it goes up against the cat but you can get it out, it is the one that connects the brake also. I put on the Rivco floor boards on my 2012 they are nice.
    2012 RTL , Brown
    Jun 2019
    jstreet
    Anyone Install Seal running boards for RT SE5....
    Nov 2018
    Waynesboro, PA
    If you have them they are easy to install. There is a video on how to install them. They don't make them any more and I think John (the man that makes them ) just sold the last set a few days ago.
    2012 RTL , Brown
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by CADRE View Post
    I have Seals on my 2012 RT SE5 what was your question>
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2019
    jstreet
    Pegasus1300, Just wondering how they looked when you received them? I just got mine and installed them. Pretty easy..
    Definitely improved how I ride... probably would not recommend to others. For the price, mine had chrome molding coming off and rubber on top of the metal plate was not cut evenly...
    Sep 2017
    Durham,Maine
    Say a post a couple days ago he's not selling boards any more, went out of business!
    2012 RTL , Pearl
    Jun 2019
    Texas
    Yes, that is the treatment to loosen the Locktite!! Just get the bolts "real warm"... but not cherry red!! ha ha
    Nov 2018
    Claremore, Ok.
    When you buy a heat gun get one that has cone focusing attachments, they are very handy to heat up a bolt and not everything around it.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Nov 2018
    Waynesboro, PA
    He has sold the last set of RT sealboards; he only has two sets of sealboards for RS se5 Spyder left. He is retiring and moving in to an assisted living home.
    2012 RTL , Brown
