Results 1 to 12 of 12
    Very Active Member cjackg's Avatar
    Chattanooga TN
    Default Brake Flasher on a Ryker
    Has anyone installed a brake flasher yet, such as this one: https://www.signaldynamics.com/backoffxp
    Apr 2019
    Kansas
    I have not yet but I pulled the one off my old bike when I traded it in to install on the Ryker. Not sure where to access the wiring harness for the brake light though. The one I have flashes 3 times then goes solid. Think I got it on Amazon for under $20.
    Apr 2019
    Florida
    I am curious also. Anyone that installed the LED light kits hook them up to the brakes? My dealer actually called CAN-AM (BRP) and were told not to hook the light kit up to the brakes, might shorten out the ECU?
    Apr 2019
    Kansas
    Quote Originally Posted by cyber2nd View Post
    Were talking about a rear brake light flasher. Why in the world would you hook up LED Light Kits to the brake light?
    Jul 2018
    Saskatchewan
    Mar 2019
    Ky
    Quote Originally Posted by Geep View Post
    I’ve been looking for a good setup for a rear brakelight flasher with additional rear turn signals. Not sure about the decelerometer but tye rest of this looks pretty good.
    Nov 2018
    N.E. Ohio
    Our Rykers slow down quickly when we just roll off the throttle even with out applying the brakes, I think I like the idea of the decelerometer to warn the vehicles behind you. I may purchase this product. Thanks, cueman
    Jul 2018
    Saskatchewan
    You can order with or without, same as signal light function, LEDs very bright. Not having a Ryker, do they slow down quickly without using the brakes aka deceleration? This was why i bought the Skene because i can come to a complete stop from highway speeds without ever touching the brakes
    Jul 2018
    Saskatchewan
    Mounted under Rivco trunk rack on my RT
    Apr 2019
    Florida
    Quote Originally Posted by KC61 View Post
    The "idea" is that when you step on the brakes all of the LED lights glow red.
    Nov 2018
    N.E. Ohio
    Geep, yes, the Ryker slows down quickly and several times I did not have to use the brakes. cueman
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    Quote Originally Posted by cueman View Post
    Same here. I need to get into the habit of hitting my brakes anyway, especially at night.
