Results 1 to 7 of 7
    Oct 2014
    Fort Mill, SC
    Default Don't lose that side cover.
    If you have ever lost a side cover, you will find that they are very expensive, $300. That's considering you had to replace the Can Am badge and sound proofing.
    In the pictures, you will see I drilled a hole in the cover and placed a 6mm fender nut on the lip underneath. Attach with a 6mm Torx screw so it looks like OEM. This is a very secure setup.
    Some folks have suggested tethering the cover, but that's not such a great idea. If the cover comes off a 60 MPH, then the cover will be flopping in the wind and flailing everything around it.
    Don't forget to put a Torx wrench in the glove box so you can get the cover off when you need to.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Default Wow...!!
    That is the best solution I have seen so far. Looks like a factory set up and very well done. congrats... and looks easy enough to do
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Quote Originally Posted by Grandpot View Post
    Absolutely a great approach to fix the issue. I'm wondering if using one of the plastic panel connectors (BRP uses on the front end access panels and elsewhere) would also work and be easier to remove if you need to. Just a thought.
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by teninospyder View Post
    I like the idea using a black push pin same as the ones that holds most of the tupperware, but the screw idea is not bad at all.
    2018 RT Limited "Blondie"
    Mar 2013
    In the 5 years and 84,000 miles that we owned the RT I never had a cover come off, but have seen others who have. I think the main issue is the small hook tab at the top of the panels are not hooked to the adjacent panel allowing them to come off. This looks like a good solution for those who worry about this.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jul 2010
    Las Vegas, NV
    Good idea! We have been using Velcro for years on that panel if the clip is broken. Invisible. Cheap, effective.
    Joe Meyer
    Sep 2014
    Scotland
    Quote Originally Posted by PW2013STL View Post
    Yes, I agree with you. That little hook has to be clipped on first then push the pins into the rubbers. Miss out clipping the hook and the panel will go awol. Don't ask me how I know!
