Just curious. Over the years I have accumulated (my wife would say "hoarded") a number of the "pencil shaped" pressure gages and a few of the digital ones.
My experience is that I can use any one of them and get a different reading - within probably a 2 pound range.
Concern is - when you are in the desired 15-17# range for your tire pressures, a 2 # difference is a lot
So does anyone know of a tire gage that is "very accurate" in this range
Ray & Marci
Tenino, WA
2014RTL Cognac
ALWAYS ride 2 up.
The most important thing about your tire gauge is "repeatability" In other words you can have a gauge that is
a couple psi off, as long as it makes the same mistake every time, on all your tires. Pick one and stick with it.
I like the gauge on my inflator, which has a flexible hose on the end. I haven't found a tire yet, that it could
not access the valve stem.
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
4Marie has the right idea pick one and stick with it but I’d suggest you check it against another to make sure it is correct or reasonably so. At the rally last weekend I checked tire pressure for a guy who definitely needs a new gauge, his left front had 24 psi, the right had 48 psi and his rear tire was at 51 psi. I adjusted his pressure and we aligned it, he thought he had a new bike as it handled so much better.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I have always put cheap tire gauges in the same category as a cheap torque wrenches. You really think a torque wrench from Harbor Freight is going to give you accurate torque
My suggestion is to buy a good quality gauge which can be calibrated, like the more expensive Longacre gauges. You can buy them from Amazon these days. LOL! In the past you had to go to a race and get in the pits to find a dealer. They now make digital gauges in addition to the bourbon tube gauges they have made for many years.
After years of use, my Longacre is off about 2 lbs I think. I'm dropping it off at System Scales to be calibrated this week. Cheap way to get the handling and mileage out of tires.
2021 Grey RT Limited, Dark Edition; Baja Ron sway bar; Spyder Pops front fender and mirror pod LED turn signals
Pencil style gauges are generally worth what you paid for them. You need a good gauge. You want it to meet ANSI B40.1 Grade B (±2%) international accuracy standard, and be calibrated when you buy it. This gauge meets those requirements accurate to less than 1/2 lb at 20 psi. You can buy it cheaper without the hose, but the hose make checking the rear tire a lot easier. https://tire-tek.com/collections/all...orcycle-60-psi
The worse thing you can have is a cheap gauge that is reading low. If it is 6lb low you are going to be at 26 actual psi when you think it is 20psi. This is enough to make a spyder Squirrely as heck. And, just because a gauge is digital does not mean it is more accurate than other gauges.
[QUOTE=And, just because a gauge is digital does not mean it is more accurate than other gauges.[/QUOTE]
Boy that’s the truth. Remember the cheap digital gauges that BRP used to put in the tool kits? They were junk
2010 RT- 622
I can't believe they would put a piece of junk on a high end BRP product.
I guess they got a deal on them and it sounded like a good selling feature.
Just found mine about 6 months ago after owning the bike for a few years. Next time I pull it out, it's going straight into the trash bin.
I have 2 from slime. One digital one analog. Both read the same. Both gauges are push on than release and read. Analog has release valve. Digital push hold button to reset. Both from Walmart.
I use the pencil gauges from Milton. Solidly built. I keep one in every glove box, under the motorcycle seat, and in the kitchen drawer. They are available in several pressure ranges - 2-20 psi, 5-50 psi, 20-120 psi, so be sure you're getting the right one - I had to take one back once. A decent auto parts house will have them for maybe $6 - $8.
I have a Wika bourdon-tube gauge that I keep in the tool box, too; a while back I collected all the tire gauges in the house and checked the pressure in my compressor tank. All of the pencil gauges agreed with one another, and were maybe 2 psi off from the Wika dial gauge.
Just got a new tire pressure gauge from Jaco superior products and it is by far one of the best gauges I have used and it agrees with my other dial gauge that is a pain to use especially on the back tire. The Jaco locks on with no loss of air and it is the type that attaches to the air hose so you can fill and bleed all at the same time. No I don't have stock in the company or work for them but I'm 73 and have used a LOT of different gauges over the years and this one is excellent. Check them out. https://jacosuperiorproducts.com
I use the FLOWPRO™ TIRE INFLATOR WITH PRESSURE GAUGE - 100 PSI
I bought one of these... Rhino USA Heavy Duty Tire Pressure Inflator Gauge (0-200 PSI) - ANSI B40.1 Accurate, Large 2" Easy Read Glow Dial, Premium Braided Hose, Solid Brass H
Sold by: Rhino USA, Inc.....from Amazon and I love it. Hooks onto valve with very little, if any, pressure loss. My tire dealer uses them also.
Tag-Along trailer
7' x 10' Cargo trailer
Garmin 396 LM GPS
New Banshee AGM
M3 TPMS on front tires
Loose Nut Behind Handlebars
