Results 1 to 18 of 18
    Member jwmorrow's Avatar
    Aug 2015
    Fort Oglethorpe, GA
    Default ZUMO GPS dies on engine start
    I have a 2015 RTL 22,000 miles with a 590 ZUMO GPS. When I start the engine and while waiting on the computers to wake up, the GPS comes alive as per normal.
    When the computer is awake, I press mode button, then push engine start. While engine is cranking most of the time the GPS dies. I then press the power button on the back of the GPS and it comes on again. When it does come alive, the screen is dim and requires going to settings and each time the brightness is on 1/2 setting,
    I move it to full bright each time and then the GPS works flawless after that.
    Any suggestions, this doesn’t seem normal and is very frustrating ??
    Sep 2014
    Scotland
    It sounds as though the internal battery is discharged/faulty.
    Apr 2017
    North Central Florida
    Quote Originally Posted by Spyderlass View Post
    This. Great GPS units; crappy battery.
    You can charge it externally with a standard USB phone charger.
    Nov 2012
    Pueblo Colorado
    I read about a fix that spreads the internal battery contacts and allows better charging while installed - It worked for my 590 LM
    http://www.totally4bikers.com/blog/b...a-few-minutes/
    I did do a full charge from the USB connector while I had it in the house and since it has remained charged..
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Bossier LoUiSiAna
    Quote Originally Posted by Easy Rider View Post
    all needed cords should have came with it, you will probably have a port under battery cover. Otherthing to try is go ahead & crank bike then attach GPS see if that works better first.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    I replaced my battery in my '15 590LM and all was fine again.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Very Active Member SpyderConvert's Avatar
    Jun 2016
    Catonsville, MD
    The battery in my 590 would not charge from the computer. Works fine when mounted on the RTL, so I thought that the battery might be bad. Purchased a new one and still would not charge when attached to the computer. Called Garmin and initially they said that the problem was an aftermarket battery. Told them that it was a Garmin battery and the gentleman said that it was probably something internal in the 590. Since the Spyder is a '15, the unit was out of warranty, but I could send it in along with $180 and they would send me a refurbished unit. Not doing it.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Apr 2019
    Clinton, MS
    Quote Originally Posted by SpyderConvert View Post
    Some computer USB ports do not have enough output to charge the unit and will not show charging when hooked up. Many times it will still trickle charge the battery so charging will take days. It could also be a faulty USB cable.
    Apr 2017
    The ports on a computer are not MEANT to supply power, even though they do a little.
    Try to charge it with a stand-alone USB charger. I bet it will work much better.......unless your battery is shot.
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Quote Originally Posted by AeroPilot View Post
    Thanks for the link, I'll be trying that.
    Jun 2016
    Catonsville, MD
    I had it on a stand-alone USB charger for 3 days and it still wouldn't charge! That was after it had been attached to the computer for 2 days. Both old and new batteries.
    Apr 2017
    Is there any other detail that you forgot to mention ?
    Seems to me like the only likely guess left is that the battery is not making good contact somewhere.
    Maybe inside the unit even.
    Bossier LoUiSiAna
    When changing my 660 on the cord FYI it automatically turns on & shows a pick of a desktop tower & cord. Does yours? may wanna contact Garmin
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Aug 2015
    Fort Oglethorpe, GA
    Thanks everybody for the helpful suggestions.
    I cleaned the contact as per the video and it has seemed to do the trick.
    I will let you know after the next road trip.
    Jack
    Bossier LoUiSiAna
    Hope it works well for ya
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Aug 2013
    Northern California
    This really works!
    Greenville Tx
    I was having these same exact issues with my 590 Zumo since it was new but getting worse lately. I wached the video posted above and did what it said to do and it is now better than ever. Thanks for posting!
    2017 F3 Limited
    Nov 2012
    Pueblo Colorado
    Glad it worked for you! Safe Ryding!!
