Results 1 to 8 of 8
Thread: brakes locked
Hybrid View
    May 2019
    Va
    Default brakes locked
    I got a 2008 can-am spyder my front brakes locks let sit about 10 minutes and they release. Anyone else had this problem .
    May 2018
    NJ
    When was the last time you flushed your brake fluid? Sounds like your calipers are binding and may need to be rebuilt or replaced.
    Default Tough one....
    Depending on all the facts....last inspected, fluid flushed, pad conditions mileage etc. The best would be to remove the calipers and check that the pistons are free of debris grim etc that is not allowing them to retract when pressure is realeased. Quick check would be to turn the wheels so you can tap on the calipers and see it they realease when locked.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2019
    Va
    Just brought bike 4 months ago only 6900 mile on it . was inspected March . tapping on it want work . let it set and it will release
    Aug 2017
    westvville,SC
    Check rear wheel if locked up when fronts are locked I would suspect the master cylinder not allowing fluid to return. The fluid probability has never been changed. New fluid and bleeding might help. Bleeding will be tough if master cylinder is gummed up.
    Dec 2009
    West Oz
    If you open a front bleed valve when locked does it release immediately as a small volume of fluid is expelled?
    Faribault, MN
    I had a brake line fail on my truck, it behaved the same way.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2019
    Va
    Going to rebuild brake system this weekend . Hope it solves the problem. Will let know
