Results 1 to 9 of 9
    May 2012
    Southern California (Oceanside)
    Default Adding fog lights to RT
    Any reasonable way ($$) to add fog lights to a standard 2018 RT? I suppose trade it in but mucho dinero.
    Jul 2010
    Las Vegas, NV
    Several offered on here for about 100 bucks. Or, try cheap versions. Put it in prospective: price a set of Clearwater Darla’s.
    Joe Meyer
    Nov 2018
    Claremore, Ok.
    Does yours have the reflectors and bulb sockets and switch and wiring? If not those parts can be bought from BRP or other places. If you can do the work yourself the cost might not be bad, but if you have a stealership do it you'll have a heart attack when you get the bill. I am very happy with the dealership parts and service departments here in Tulsa, Oklahoma. They seem to be the exception from what I've read here on this forum.
    Dynojet Power Commander V, Power Commander POD-300 Display, PCV Map Switch
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New AGM battery (01/24/2020) with Battery Monitor and APP
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    May 2012
    Not sure about the wiring, maybe buried within the RT.....no switch on dash.
    May 2012
    Apr 2017
    North Central Florida
    In my 50+ years of driving cars, trucks and motorcycles.......probably several hundred different models because I worked for a rental car company for a while.......
    I have never seen "fog lights" that really did any good in fog.
    Might be somewhat useful under normal conditions though.
    Jun 2019
    Canuckistan
    Quote Originally Posted by Easy Rider View Post
    Oh, they do exist, yungun', lol.
    Quick examples - there are others.
    https://www.hidplanet.com/forums/for...ector-showdown
    However - unless you do the work to retrofit effective units onto yer trike, none of the current 'kit' offerings are worth a damn as dedicated, effective fogs. But - as a Frontal visibility aid, sure. To me, though, that is simply a waste of a lighting position just begging fer improvement.
    FWIW - I went with the X5 as they were a steal @ $10 in a TRS Closeout sale, and they were just sitting in my shop waiting for an application.
    FWIW #2 - any of those would work fine as DRL's and if you need to venture out in fog you need to drive very slowly anyway or you'll overdrive any of them.
    FWIW #3 - you can apply Laminix film to render the fog-preferred ~3000K color temperature if ye wished.
    Cheers
    E
    May 2012
    I am interested in the fog lights for visibility (me being seen) and aesthetic reasons not so much for seeing in the fog.
    Jun 2019
    Canuckistan
    Quote Originally Posted by Thopper View Post
    Howdy;
    Then yer in luck - as just aboot anything that fits will do.
    Nothing wrong with aesthetics - the problems arise when folks have unrealistic expectations from poorly-engineered / misrepresented products.
    Everyone is different; I respect that. I'm just a function-over-form kinda feller, is all. I abhor squandering a genuine opportunity for improvement over 'bling'.
    Best o' luck. As others have stated - with some homework and due-diligence research on the various parts sites, ye can gather the requisite OEM part numbers to add what components are missing, and get a ballpark feel fer the total cost and effort involved. Then you can decide if it's worth it - to you.
    Cheers
    E
