Results 1 to 8 of 8
    May 2019
    Kelowna BC
    Default Proper jacking, bracing and oil change on 2010 RT
    Any tips on proper jacking, bracing and oil change on 2010 RT ?
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    My favorite way to lift it is to get three car ramps. Place them backwards behind each wheel, then backup onto the ramps.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Nov 2018
    Waynesboro, PA
    Very carefully is the best way. Lots of ways you can do it, I use a jack and 3 jack stands jackedup sl.jpg That way I can get under the spyder and look around at everything at the same time. in this photo I was doing a lot more then oil change, but you can see it gives you plenty of room with the jack stands.
    2012 RTL , Brown
    Oct 2016
    Faribault, MN
    I use the very reliable Harbor Freight Pittsburgh 1500lb ATV lift and three jackstands.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Apr 2019
    Florida Swamp
    2019 F3-S , Black & Silver
    Default Can't help.....
    I still do all my oil changes on the floor. The only other way would be with a full lift but that is not in the budget. I do have the craftman ATV/motorcycle lift for all other work...
    ​2012 RS sm5
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    There are already a lot of good ideas provided and you can find many threads on this. The only thing I'll add is I generally don't jack mine up at all as you don't have to if you have a low profile oil pan. If you don't you likely only need to raise a couple of inches. You don't need to over do it and risk damage to you or the bike.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    I have changed oil on my 2018 RTL while flat on the floor, tricky but can be done. A couple more inches would be great. So, I built 2 ramps made out of 2 x 10 wood. Easy to make and really cheap. The bottom part is 24" and the small part on top is 12". If you can, make a 45 degree cut on the edge, but not necessary. Drive the bike on top. Give you an extra 3" and make the job a lot easier.
    2018 RT Limited "Blondie"
