Results 1 to 16 of 16
Thread: ECU Flash
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default ECU Flash
    Anyone know of an ECU Flash for the Ryker 900 yet?
    2022 F3 Limited , Monolith Black / Dark
    WI.
    Fast Ryker has one. http://fastryker.com/tuning
    Power Vision has a unit http://www.dynojet.com/powervision/p...7253&mkn=Ryker
    Fuel Moto has said they will be working on tunes later.
    Nov 2018
    N.E. Ohio
    Why don’t I see any before and after dyno results? cueman
    WI.
    Ft Pierce/Lk Placid
    Quote Originally Posted by NathanL View Post
    But is actual torque any better? Higher torque is way better than HP.
    The one says "higher RPM limit". That's dangerous! You could BLOW an engine exceeding manufacturer's determined MAX safe RPM!
    Jul 2019
    TN
    Of course when HP goes up at any given RPM torque must go up as well.
    Jun 2011
    Alamogordo, NM
    Quote Originally Posted by Stephenj37826 View Post
    Correct...............
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    That's not true. Horsepower and Torque are equal at 5252 rpm. After that torque starts dropping while horsepower keeps going up.
    Mar 2019
    GTA, Canada
    HP and TQ don't really go hand in hand... if one goes up, doesn't mean the other one will automatically go up as well.
    California
    Quote Originally Posted by mrNewt View Post
    HP and torque absolutely go hand and hand. Kind of odd to see people strugging with this, basic equation:
    HP = Torque x RPM / 5252
    You can increase horsepower by increasing rpm. However, if torque drops so will horsepower. 300 lb-ft at 5000 rpm = 285 horsepower. 200 lb-ft at 6000 rpm = 228 horsepower
    C'mon people, you can discuss the subject, you can even disagree on it, but the moment you start getting personal & attacking each other rather than politely discussing &/or disagreeing, you are risking your posting privileges!
    Please, post politely, or not at all!
    Mar 2019
    GTA, Canada
    Stephen, you say the following...
    And then Sticky give this equation:
    Based on this equation (which I know it very well), you can clearly see that the HP is dependent on TQ and RPM. TQ by itself is not enough to drive HP up.
    In other words "at any given RPM" TQ does not necessarily needs to go up as well. HP will still be going up even when TQ drops because of the higher RPMs.
    There are tons and tons of dyno sheets out there that you can Google by yourself and you see TQ dropping in higher ranges of RPMs but HP still goes up... because of the multiplication between TQ and RPM.
    But anyway... I'm done with this subject, night all.
    Jun 2013
    Uniontown, Pa
    And none of this has anything to do with the original question
    Jan 2018
    NH
    Quote Originally Posted by DriftersWay View Post
    Well, technically we are still talking about HP and torque curves. And that's what the ECU flash does.
    At least we're not arguing air speed velocity between African and European swallows and their ability to carry coconuts! :-D
    Jul 2019
    TN
    When horsepower goes up at any given RPM ie 5000 rpm you had to have had a subsequent increase in torque at 5000 rpm or you would not have more horsepower....... Especially looking at the posted dyno chart you can clearly see an increase in horsepower at most rpm until it reaches 7400+
    Last edited by Peter Aawen; 08-07-2019 at 06:33 PM. Reason: Removed un-needed snarkiness!
    Jun 2019
    Florida
    Quote Originally Posted by Aufgeblassen47 View Post
    On my Harley, I had the rev delimiter firmware download right after I purchased it. I was worried about it being dangerous to the engine, but I never blew it up. I never had it done on my Road King and it seemed like whenever I needed the extra power when jumping out and passing, it wanted to bog down. My Softail had no limit on it after the firmware download. Just saying. To be honest with you, I have not put but a couple hundred miles on my new Ryker Rally and I have yet to see an instance where I need any more power. This thing jumps forward from 50-60mph like it had been sitting still. At least it seems that way. It's weird not having to down shift or have it go into a passing gear to pass.
    But, everyone has their reason for modifying the speed and torque. I respect that, and feel that if you have the money to possibly throw away if you damage your machine, then go for it. You won't get any judgement from me.
