Results 1 to 11 of 11
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Charging Station
    Charging station for the Senas and the battery tender done. Battery tender is plugged into the Lamonster Powerplate on the Spydercuff and works great!
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Apr 2017
    North Central Florida
    Do you connect your tender every time you park the Spyder in the garage ?
    If so, that really is not a good idea.
    Default Well done....
    Have a similar set up for the Scala G9's and the Mp3 player... even have he same color scheme helmets... Looks great...and functional..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2018
    Chateauguay, Qc, Canada
    Please explain why it is not a good idea.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    May 2019
    Carlton
    Mine is connected all the time im not riding it... so were all my other bikes with no ill effects. Its a battery maintainer so is designed to be left connected.
    Bossier LoUiSiAna
    Quote Originally Posted by Curlytops View Post
    newer maintainers yes, older trickle chargers no leaving on overnight or some other time gap around 12h max at any given time,otherwise various I’ll effects & dangers have occurred. Quick reference:
    https://www.chicagotribune.com/autos...11-column.html
    Apr 2017
    The problem comes in when the battery finally DOES reach the end of it's useful life.
    With the tender connected, that pretty much guarantees that it will start every time at the beginning of the day.
    So when the battery finally fails, and they all do eventually, that will almost certainly happen at some place that it is inconvenient.
    Maybe VERY inconvenient.
    This has happened to me.......once.
    To several others on here too, IIRC.
    It is better to connect it ONLY when you know it will be unused for two weeks or more.
    If it is ridden every few days, there really is NO NEED for a constantly connected tender.
    Jun 2018
    HAYMARKET,VA
    No, I do not. It's just ready for the next winter this way.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Nov 2018
    Claremore, Ok.
    I like the color schemes of your helmets, they'd match the colors of my 2015 RT-S Special Series. I have a shelf in the shop where I charge the Sena 20s EVOs. I pop them off the helmets and put them on the shelf. It's much easier to stick in the Micro USB plugs with the units off the helmets.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Revalden View Post
    The helmet on the left actually has a spider on the back of it. We got it years before the spyder though.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    If you thought you liked the color scheme, check out the back! I bought this years before i ever even thought of a Spyder.
    Baja Ron Sway Bar
    Key Cover from Ebay
